LED Solar rechargable lantern with mystery supplied cells?
Hi, I bought a useful looking rechargeable LED lantern on Ali Express for £6/$8 with the intention of modding out the low-capacity 18650 cell these things normally come with, and replacing it with a homemade, high capacity, protected dual 18650 battery pack.
However, when I opened it I found it had 3x ‘AA’ type batteries installed. When I removed these I found they had an indicated voltage of over 1.6v? I’m used to Ni-Mh being around 1.3v, and I’ve heard of Small ‘AA’ sized Li-Ion’s that have circuitry to drop their voltage down to 1.5v - but these normally have a USB connector fitted to allow charging. My only other thought is that they may be Ni-Zn batteries, as, apparently these are 1.6v, but I’d be gobsmacked if they have found their way into this cheap as chips lamp? Anyway, I peeled some of the wrap off but could not see any thing useful, but I did find out that the positive connection and the case sides are connected with the negative bottom being isolated? Very strange way of doing things. I’m pondering whether to replace these with the dual 18650 setup I had planned or whether it would be worth keeping them - although I imagine the capacity of the three would still be less than the 2x 1800+ mAh I’d get from a pair
of recycled Samsung 25R’s I have waiting. If I don’t use them in the lantern again, how on earth do I charge them? It’s all very strange. Any thoughts?
Lamp I bought
e
Either overcharged NiMH (directly connected to USB input) or very low discharged Li-ion (but then the case would be negative).
I forgot to say, there was a charge indicator on the side (This is a very well specced cheap torch!) and it showed full charge before I took out batteries. I tested the voltage supplied to the battery pack when a charger was plugged in and it was 4.65v. Overcharged NiMH might be a posibility I suppose, but I don’t think they could be
very low Li-ion, as they were wired in series and that would be over 12v they would be providing, whereas the setup looks to be either 3x1.2v or 1x 4.2v as is usual in these lamps.
How about rechargeable alkalines? Those can last a lot of cycles, if the discharge is modest (ca.25%).
Without doing major surgery to the innards, you can stick 3 14500s in parallel, use a scrounged charging board like for a lipstick-type powerbank.
I think I will convert this lamp to 2x 18650 in parallel. It has the support brackets for 2x 18650’s, so hopefully the circuitry will be able to cope with this. I’ll run them through a protection circuit - that should help with any charging/discharging issues.
I’m just very puzzled about the chemistry of these cells. For the cheap price of £6/$8 I’d have expected low-capacity Ni-Mh cells, so was surprised when my meter showed over 1.6v for each (after over a day out of the lamp they are still showing around 1.625v, so no massive voltage loss) I can’t believe the manufacturer would fit anything exotic (rechargeable alkalines or Ni-Zn) but what else would make 1.6v?
To me this is a total mystery, I do not have a (known safe) way of charging them up (to what voltage?) if I discharge them, and I do not have a way of testing capacity. So If there is anyone on this forum, in the UK, who does and has past experience in analysing and investigating cells and would like to have a go with one of these, please PM me and I’ll send you one. Thanks, perplexed :face_with_head_bandage:
Have you verified the voltage reading of the DMM?
I may have misunderstood, are you saying the body of the cell is positive and the end is negative??
I’ve checked the voltage with other meters, and yes, the positive cap and body are one piece and the negative end is isolated from the positive body (I see now not very well isolated, it’s scary to see how the negative’s nickel strip must have been a hair away from shorting on the positive case, just relying on the shrinkwrap to provide isolation, when installed in the lamp!). All in all a very strange arrangement, it’s the first cell I’ve seen with this setup - never mind the curious voltage. See the below pics.
I’ve fitted the 2x 18650 protected battery pack I made up. and all seems well.
I ran the lamp for several hours last night to drain the cells so I can see what the lamp’s charging circuit does to them when I plug it in. I imagine there is no cuttoff circuit on the original board and so it would just supply the USB voltage to the cells. Thinking about it this makes sense, because if the batteries that the lamp had originally were basic Ni-Mh’s - and there was no cuttoff circuitry - I imagine they could get charged up to over 1.6v by just being connected to un-regulated USB power supply. Strange, but I suppose it’s possible that they are just basic Ni-Mh’s then, that have been grossly overcharged, and nothing mysterious. If that is the case I’m doubly glad I swapped them out for my protected 18650 pack!
Left the lamp charging for a few hours and checked it. My 18650 battery pack voltage was up to 4.25v (which is around the 4.25±0.05V peak charging voltage of the 1S BMS I had fitted) so I unplugged the charger then. The onboard charging indicator light only had two out of the four LEDs flashing, so I think that was still going to keep pumping volts into the battery pack. Luckily it has the BMS - although I wish there were 1S BMS circuits available that cut off charging around 4.2V, maybe there are, but I can’t find them, all the ones I see seem to be cutting off at 4.25v or higher! All in all a great lamp, with 6 modes, a decent solar panel for additional charging, and a USB socket to charge your phone! Now that I’ve upgraded it to two good, matched voltage and resistance, Samsung 25R 18650 cells (free Laptop battery repurpose, from a local recycling center) and stuck a cheap BMS on them, I’ve got a great, cheap multipurpose lantern that runs for hours. I Must look into swapping the micro USB socket out for a USB ‘C’ one and it would be perfect! See below for pics of my 18650 install and details of the original control board - can anyone tell me if it looks like there might be some voltage regulation on it?
PS: MOD’s please feel free to move this thread to the Modification forum if you like as it has sorta grown into that from my initial ‘head scratching’ post about weird 1.6v cells.
This are mostly just simple protection circuits, even though they are called “BMS” by sellers. They are designed to never be triggered during normal operation, they are supposed to be used in combination with proper CC/CV charger which terminates at correct voltage and are intended as redundant safety device in case if something fails and charger tries to overcharge the cell or something, not primary means of limiting charge/discharge voltage. That’s why charge/discharge cutoff voltages are usually set a bit above/below normal.
Using li-ion cells like this is a bit naughty, it’ll work but it will have significantly higher risk of catching fire than normal and will kill the cells faster than normal.
True, it’s not ideal - but it’s gotta be slightly safer than the supplied cell pack of 3x Ni-Mh (I can’t think they were anything else, at the $8 price point) that were being charged up to 1.6v! I’ve seen many of these type of lamps using Li-Ion cells (in fact the one I have has the recess for 2x 18650’s already and they just stuck the 3x AA pack loosely into it, so I imagine the original intention was to use 1 or 2 18650.
True ‘BMS’ or not, it’s more protection than the lamp originally came with, and I’ll take that - with your caveat noted. It’s my own lamp and I am now aware of its foibles, and I’ll pay attention to it when charging (as you must do with these cheap Ali-Express devices anyway). Thank’s for your useful comments.
You can buy USB single cell charger boards very cheap though, sticking on of them in there might be a good option. At the very least it will increase cell lifetime and likely - runtime since it’ll do proper CC/CV charging.
Also cheap ni-zn cells do exist, take a look at pkcell store (918700) on aliexpress. Not saying that this cells are ni-zn, but it is definitely a possibility…
That sounds like a good option, I have bought these in the past (they are 3A charging but you just remove a resistor to knock that down to 2A, my pack is 2x 18650 so that should be ok, if they get hot I’ll add a 135k resistor to knock that back to 1A) and will probably stick one in this lamp, if nothing else I get the USB ‘C’ port I wanted :+1:
USB ‘C’ board I bought
The only problem I can see with the CC/CV charging modules is, that although they do a good job of regulating the charging voltage/current going to the cell, they dont have any battery protection features for over-discharge, so I think I need to use them feeding into my ‘BMS’ board, feeding into the cells.
I’m almost certain those were rechargeable alkaline batteries. 99.9%. Only thing they can be. Crimping at the negative terminal, check, button on the other, check. They’re the reverse of lithium ion. 1.6v, check. Super cheap from a sketchy AliExpress store, check. Definitely rechargeable alkaline. Checks all the boxes. We don’t use them over here anymore but we used to. I’m sure they still use them in Asia somewhere. Probably somebody rewrapped them to look like li-ion.
My parents used to buy us these for our Gameboy Colors back in the day. You put them in this see-through case that would click into the back of the gameboy, and that’s how you charged them too. There was a little AC barrel that plugged into the case, and then when it was time to go somewhere you just unplugged it and you had battery. They were only good for a few weeks, idk what we got out of them, maybe a few dozen cycles. Then you’d take the old ones out and put new ones in. Eventually they stopped buying us new ones and we just played with the AC adapter.
Then one day I couldn’t find the AC adapter so I just grabbed some other thing with a barrel plug and stuck it in. Now idea how many volts that was or what it was for. And that’s how I bricked my gameboy. Memories.
Hmmm, I think you might have something there Mr Goldblum. (RAM) Rechargable Alkaline? That hadn’t occurred to me, be strange if they were. I have no way of charging them - apart from putting them back in the sketchy charge setup in the lamp, which I have since swapped out for 2x 18650’s - so I’m afraid they are destined for the great recycling center in the sky (unless someone in the UK wants to send me some P+P for them) I’m pretty sure I’ve made a good mod now though, 2x Samsung 25R’s must surely have greater capacity than 3x Noname rechargeable alkalines. RAM seems very fussy about depth of discharge too, with the recommendation to only discharge down to 75% of capacity to get a few hundred cycles, or if you deep discharge them then you only get around 25 cycles. No wonder they never caught on. I found a pic of one with the smoking gun negative end crimping!
RAM
Yeah, you can and should use both charger and protection board. This is how they are usually used in commercial devices (phones etc).
IMO 2A is totally fine for 2 18650 cells in parallel, the only concern would be how hot the charger itself gets.
Oh ya definitely toss those things. We only used them I assume because was cost effective for my parents over us going through a half dozen Duracells everyday. I don’t remember NiMH or lithium ion being a thing then.
