Specification
Input voltage:AC 100-110V or 170-240V AC/50-60HZ
Consume power:270W
Light source:90pcs*3W RGBAW LED, 7520 Lumens output.
Lamp Spec:R(18PCS), G(18PCS), B(18PCS), A(18PCS), W(18PCS)
LED span: 50000~100000 hours
LED PWM dimming frequency:>450Hz
Control signal:DMX512,32 bit precise dimming, smooth in low DMX Value dimming, not Jumping, no vision shock
Dimming mode: nod0 linear dimming, nod4 square law dimming. nod1-3 Delay dimming
Control mode:stand alone/ DMX/ master and slaver
Channel:4CH、5CH、6CH、10CH、16CH、20CH
Color effect:R、G、B , A, W mixing
R=625nm, G=525nm, B=460nm, A=590nm, W=6500K
Function Effect:dimmer, strobe, gradual change
Beam Angle: 8°, 15°, 25°, 45°,60°, lens easy replace.
Cooling mode: Fans cooling
Anti-electricity intension:1.5KV
Insulation Resistance:>2MΩ
Protection rating: IP20
Net Weight:10KG (With package 11 Kg)
Package Size: 107*29*22CM(1 in 1)
9600 Lumens at full output.
This product comes from:
Features
Unique cooling mode, light source and control completely separated, fan cooling mode
DMX512 Controller,DMX ID address with 4 digitals display with On/Off function
Both linear dimming and square law dimming are available, and could be chose even at controller from last channel of each channel configuraction.
Master slave/interconnected multi-machine control
Lens degree: 8°、15°、25°、45° 、60° optional, lens easy replaced just need to open lens panel.
Using switching power supply to protect the LED to work well
Strobe、gradual change、jumping change
Easy package and easy carry, Easy installation and uninstall with fast-do screws.
PowerCon connector inside, offers to connect 12 PCS in series in 220 VAC and 6 PCS in 100V.
