A D3AA is going to be pretty floody with almost any emitter config, simply how a triple optic works. If you want more throw, you should look into a single-emitter light.
Under maximum current for all emitters, the FFL350RD throws a bit more than dedomed 519A or FFL351A, but likely not very noticeable unless you do a side-to-side test. The high Vf and masked square LES make it significantly less efficient than the 351A/519A. However, if you plan to use med/low modes most of the time, the 350RD can crank out significantly more throw at the same drive power, just because of a smaller die.
