LEDs/MCPCB easy replacement
That may seem like a silly question, but is there (or could it be) a system that would allow changing LEDs/starboard/drivers in flashlights just like changing lightbulbs or some other plug and play components?
I imagine soldering is good for resistance and heat conducting, but could there be an easier way that wouldn’t skimp on performance either?
There are many spring loaded tool less clamping systems for the square COB leds.
so it would be easy to adped such a system.
but they are usually for high voltage leds with around 50v or so to keep the current low
I believe the Frazlabs lights use a bolt-down system which doesn’t require soldering.
Generally, I’d describe standard MCPCB LED swaps as fairly straightforward, lights from the premium manufacturers are often more difficult to open than the driver wire soldering is.
Next level of difficulty is re-flows, but given most popular leds are available on boards, I’d say this doesn’t matter that much.
Boards with components such as thermistors or Aux LEDs are a bit more challenging to swap.
