Let me give you a reason to buy a small CNC!
Salut!
I have bought a Lunyee 3020 Nova some time ago, but shortly after - two weeks ago - I got the chance to get my grimy, sweaty, sticky, filthy, grabby hands onto a Makera Z1 reviewer set - so the machine with esencially all the add-ons for a ridiculousy low price.
Today I tried something with an old Convoy M21H TIR Lens. I want to use a 5000K High CRI NV1010 as a spot for an aquarium. I am using this setup with a 5000K FC40 already, but I want to try it with a different LED.
So I had to mill the lens to fit the larger LED.
No problem at all!
Find the center of the hole with the 3d probe, lay some thin metal piece on too to get the Z-height and start milling using a 2mm 3 flute carbide cutter.
At first, I put some alcohol in the center hole for some cooling, but it’s neither needes nor good for the double sided tape taht I used to hold the lens down, so aI removed it after this picture.
The spot is just perfect
Of course, you loose some light that doesn’t make it through the milled surface, but that’s a downside I am willing to make. Also, the majority does get through the center hole, so no loss here.
11 Thanks
:+1:
Nice Project. Have fun with your new CNC.
maybe you can uses this “Vapor Headlight Restoration Kit” things on it to make it clear?
or just a drop of silicon oil
Today, I tried it with the 3° lens (at least the lens that was in a bag labeled 3°)
The spot is quite narrow for this size LED, but it has some weird artifacts in the middle.
Probably good enough for an aquarium, but not for a flashlight.
At some point I will definately build a 18650 light with a small lens in it and the NV1010.
Tried it yesterday:
In the last two passes, some material melted onto the mill and that bloib just melted its way through the material.
But it does work. Quite a broad spot, of course, but much more usable than a mule.
Before:
Now:
Looks nicer and the LED is perfectly centered because the optics literally snap onto the LED.
Beam is floody (surprising, I know) in both ways, doesn’t really matter if you have a 5mm deep reflector or lens in front of a 10x10mm LED :smiley:
Edit: Yes, it’s not the same LED. Was the 5500K lowCRI Version, in the new picture it was 4000K HighCRI
Well, well, well-
I had a lens, a CNC Mill and time.
Combine those three and this is the result:
As a surprise to noone, this doesn’t really work, it’s just a very inefficient diffuser. But at least we know this now, before we just speculated :microscope:
damn, this is some serious modification.
how much did it cost you?
Yesterday i do a mod for one reflector and after one hour of work with mini hand saw it’s a fail..
I created a floody with a black spot in the middle..very horrible..
I order some new reflector for future modification
So, you bought one of those heatsinks from AliExpress that are designed to have airflow.
But how do you attach a fan to that thing?
impossible with anything else than a mill, i guess.
Of course I planed the backside. The threads were made on the machine, too.
The threads are M4, 3,2mm hole, 0.6mm chamfer before thread-milling.
Now the wait for the M4x50 screws begins…
