I recently dropped a 26650 unprotected battery from a height of 4 feet onto a solid wood floor. The battery landed flat and does not have any physical damage. Is there any way to determine if the battery is safe to use or should I just discard it ?
Inspect it for dents or cracks in the sides anywhere. if thee is no dents, and you have a smart charger you can test it for the internal resistance & capacity to see if the IR is high. If there is no dents or marks, it should be fine. i dropped some 18650 cells before on concrete floor with no problems after.
