Hello. I’m embarrassed to ask because I have been around of many years I have had (2) cells go bad lately. These were in lights that have a side switch. Is there a drain in these types of lights? When does a cell go bad, at what voltage? And can they be brought back to life? My latest was a 14500 WindyFire, it read .98 on the meter. I just checked again and it is now up to 2.5V. Maybe it will still be ok?
With some 70+ lights lying around, it’s hard to monitor them all. Guess I need to do a tailcap lockout on the side switch lights? Please correct me if my assumptions are wrong.
It is my understanding sideswitches kind of “wait for press” and are using a little bit of power doing so
I keep them locked out (or prefer a second tail switch for the lockout)
It do not have anything directly to do with side or tail switch, it has with electronic or mechanical switch.
But a side switch is much easier to make electronic than a tail switch!
One way to spot an electronic switch is that it is a push button only, it do not lock in on position.
Yes, that would be an electronic switch. Some lights have almost no drain and some tend to draw a little more. I know, very general statement… But, do watch the batteries every few months.
We call it “parasitic drain” and as others have said it varies from almost nothing to horribly high. Anything with high drain is a pure piece of junk, worthless imho. Ensuring the drain is low is a requirement for making even a half-way decent side switch light.
I found out the following about my Manker T01 which has an electronic switch:
Yes it does but the current draw is so miniscule as to not be a concern; it’s 6 microamps which should last about 48 yrs on standby with an Eneloop XX (leaving the cell’s own self-discahrge out of the calculation) or 4yrs with a typical 14500 cell @ 600mAh capacity (again leaving the cell’s self-discharge out of the calculation).
48 years! I’ll be long gone, I’ll have to add an addendum to my will.
