So for my next Halloween project I got several 3W 365nm LEDs from Epistar, pre-mounted on star PCBs, as well as these heatsinks:
and some 41.5x2mm ZWB2 filters.
I plan on running the LEDs at 350mA instead of their rated 700mA to help keep them cool. Even at 350mA the LED already gets hot to the touch after a minute or two, although not boiling hot. I don’t have any equipment to measure the temperature unfortunately but I don’t think it gets excessively hot with this current.
I’ve come to realize that I will need some sort of fixture to mount the LED/heatsink combo and the filters. It will have to be tiltable. The base of the fixture should have a magnet for easy attachment to the metal doorframe. Swivel is not required since I can just rotate the entire magnetically attached fixture.
Of course if I replaced the Epistar LEDs, which have quite a bit of stray visible light to them, with Nichia LEDs I would not need the filters so that would make the fixture a bit easier to produce.
What would be a good source for Nicha UV LEDs, pre-mounted on a star PCB?
Are there any readily available off-the-shelf components that would make it easier to build a fixture like this and where can I get them?
Since the LED is already getting somewhat hot I guess the fixture will have to be a fairly open affair as as not to block the flow of air.
I could design and build something from scratch out of stock sheet metal, threaded stock and some 3d printed parts (to hold the filter) but that will be quite a bit of work. I’m hoping there are some components to make this easier.
Any suggestions?
