So I’m already going to have to get a new DMM so why not get a lumen measuring device to boot? Where can I get one and how much will it set me back?
Lumen measuring device isn't trivial. You'll need an integrating sphere (bought or home-made) and then you'll have to calibrate it to a lux meter. If you're talking about a lux meter only, then they are available from lots of places for between 30ish dollars and multi thousands of dollars.
PPtk
$13.62 from FT:
http://www.fasttech.com/products/0/10003840/1274500-hs1010-illuminance-brightness-light-meter
Seen cheaper in Aliexpress but then you have to forgo Paypal etc…
Only problem with the HS1010 from FT is the sensor and screen are attached. That can make it difficult to get sag readings off of an integrating sphere. If the HS1010 is good enough for you, let me know, I have one that's redundant now.
