I’m needing some help with my recent battery charger purchase. I’ve always been interested in flashlights and am wanting to start buying higher quality cells to run in them. I purchased a LiitoKala Lii 202 as an entry level charger. Can someone please explain to me when i should or shouldn’t use the 0.5A and 1.0A function.
I also put some AA sanyo eneloops in there that had been laying in a drawer for over a year. They would only charge to 50%, no higher. Is it possible these cells could be bad? Thanks in advance for your help.
I`s best to charge at half the battery`s capacity if you can, so for an 2000mah Eneloop charge it at 1000ma 0.5C , Eneloops can be charged at 1C or 2000ma but a slower charge makes the battery last longer.
Yeah, the higher the charge current ma, the faster a battery will charge, But charging fast causes the battery to get hot and this can reduce the battery`s life, so it`s best to stick to between 0.5-1C
About 10-20% of the power you put into a rechargeable battery is wasted as heat, So charging an empty 2000mah battery at 2000ma you would think would take 1hr but you have to add and extra 20% time, So about it`s around 1h12m
Have a look at the Battery University website for a lot of information on how to charge and care for battery`s
New or battery`s that have not been used for a while can stop charging before they are full, I feel the battery if it`s cold then i re-insert the battery and try charging again.
I may have not given the eneloops a fair shot at charging. After an hour or so they wouldn’t get past 50% so i took them off. I’ll put them back on for a few more hours and see what happens.
I have the single channel version of this charger the LiitoKala Lii-100, I have noticed the battery gauge does not seem to be very accurate when it comes to nimh battery`s and an lot more accurate for li-ion battery`s
OK, my bad ‘bhorn’; I know what your talking about now. The little blue lights on the face of the charger.
I just never pay any attention to those. I just wait for them to quit blinking.
Chance are you are right, you did not give them enough time. If you were charging at 0.5A it would take right at or over 4 hours if they were very depleted when you started.
