Limiting Current in Direct Drive?
Hi all,
I am sure there is a simple answer to this. But as the title says, is there a way to limit current when running direct drive?
The reason I ask is I was planning to use an MT-G2 in the Uniquefire UF-1405 I just received. However the driver cavity is smaller than I was hoping it would be and I don’t think I will be getting any decent sized driver in there. So the other option would be direct drive, however I have read that an MT-G2 can pull up to 10A in DD which does seem excessive in this host even if I only will run it for short periods.
I have either Keeppower Protected or MNKE 26650s. I’m assuming the Keeppower will be able to provide lesser current of the two given the MNKEs are rated at 35A.
So any info on this?
How big is the driver cavity? The simplest solution is a Zener modded qlite driver with either extra stacked chips to get beyond 3A or a slave board. A larger diameter cavity might accommodate a board with more chips w/o stacking.
With 2S King Kong ICR cells and no driver, I usually see 6+ amps. Lets just call it 7 after DMM losses. The KK's sag more which drops current.
22AWG wire won’t be able to carry over about 7A to a single emitter (tho I have personally watched 2 single strands of 22AWG silicone wire deliver 13.5A to a triple XP-G2 Noctigon) but even to SST-90’s and MT-G2’s I’ve not been able to run over 7A threw 22 to just one emitter.
I’ve not yet reached the limit if what 18AWG silicone wire (120 strand) can carry and my one MT-G2 light pulls 11.3A from 2 25R’s with a 20dd Z so that’s an option for limiting it.
Why not use a driver tho? You won’t be able to use protected cells in series so the driver [even if you only want a single mode] will at the least offer you LVP.
Edited cause my Stupid thumbs can’t type today, I’ve been soldering all day long for 3 days straight.
Thanks for the input guys. I’m at work at the moment so can’t check the size of the driver cavity. I had actually thought about using a zener modded Qlite with stacked chips but I thought to get the current I wanted I would need to stack at least 8 chips but probably more. I will give DD a shot and see what it pulls. I don’t plan on using this light much, I really just wanted to see what an MT-G2 would do behind a reasonable size Ltd aspheric.
Using normal ICR cells instead of IMR/INR is the easiest way to handle it. Bonus there is that the ICRs usually have higher capacity, so that combined with the lower amp draw dramatically extends runtime, you just get less peak output.
So some King Kong ICRs or are there others that you would recommend?
22 ga Tenergy leads from a BLF17DD in a TangsFire TS2010 to an Luminus SBT70 give 16A from a single Efest 35A 18650.
Same wires in my M8 with a Zener modified BLF17DD give over 12A to an MT-G2 with a pair of Efest 35A’s. Direct drive in this light was almost 16A (15.84?) to the MT-G2 if I recall correctly.
I find the performance is optimized between 5 and 7A for the MG-G2, seems to deliver the most output for the heat and consumption for me in that range.
That Luminus really surprised me after all the Cree I’ve played with!
I have ordered a Zener modded BLF17DD from Mountain Electronics. Just deciding what batteries will be the best option to go with at the moment.
Look through HKJ's recent +5000mAh 26650 reviews (you probably already are), seems like one of those new hi-capacity cells will be the best bet.
LSX, I was going to suggest you ask RMM to do his PWM firmware magic and limit max output. The BLFDD driver reaches as high as10A+
It depends on the cells & how many cells & how many LEDs...
Single 18650 light with 3-up XPG2s & BLF-17DD, runs at 8.5-9A from a 25R, but only around 5.5A from a ICR 28A/26C. More LEDs will increase those numbers, as will adding cells in parallel. But that's a big difference just by changing to a different flavor cell.
That will be ok as it has lower modes. I was more concerned with having it in Direct Drive only as it would be pulling high amps every time it was used.
Yeah, you can't kill a MTG2 with only 2 cells anyhow. :party:
