Linger Special v2 - simple mod
I bought a Linger Special from nailbender back in 2011. If you guys don’t know what a Linger Special, it’s a P60 drop-in that has two XP-Gs mounted side by side. The beam profile of it is essentially all flood.
For some reason or another, I couldn’t get to bed the other night and I was looking through the flooders that I have. The Kerberos quad XP-G R4 was still plenty bright, nothing to do here…and also because I don’t want to meddle around with a drop-in I paid US$140 as well. :slight_smile: Then I looked at the Linger Special, turned it on and felt, under whelmed by it. Maybe because it was an XP-G Q2 3000K 7A3 (90 minimum CRI) that I didn’t feel like it lacked some punch. So I went back to the original for sale thread in CPF and found that it was only driven at 2.5A and I thought to myself, I might be able to do something about that.
Went into the drop-in and found that it was driven by your typical Nanj driver. Part of the whole getting prepared to mod my lights, I previously bought a whole bunch of 350mA and 380mA 7135s, that, up until the other night, have yet to use. So, this is my first effort in stacking these things.
The host is a Solarforce L2T. The tailcap spring has had the copper wire treatment.
Front view.
Stacked chips.
The outcome? Well, the tint, in my opinion looks better. Less yellow and more creamy. It’s certainly not as white as any of my 4000K lights, but it looks less of an incan now. Also, the low and medium outputs seem more usable now compared to before. Before the mod, to get any usable light, it felt like I need to always be using it on high, but medium is now bright enough. Stacking two 380mA chips, it’s now at 3.26A. I didn’t get a before the mod tailcap reading, but now, it’s reading 2.2A with a NCR18650PF and 1.8A with a NCR18650A. I will be using the latter cell for day to day use. Any way, the PF is a much shorter cell and it doesn’t make contact to actually turn the light on.
I am half tempted to add one more 380mA, but I think I’ll leave it as is…for now.
Album of pics for full resolution.
Good job .
Thanks for sharing your success story .
Nice one. Its an interesting light you modded. After the last few drivers you have played around with I’d suggest not to push your luck. :slight_smile: Looks like I have someone that can add chips to my drivers locally now. :wink:
Did this. I thought, may as well…
So it’s now 3.64A compared to the original 2.5A. Tailcap readings are now 2.45A with NCR18650PF and 2.1A with NCR18650A. I did clean up a few solder points as well. Is it brighter? Can’t tell. With the added 3*380mA now, it sure does get hotter than when there were two of them.
edit: switch didn’t like the extra 380mA so I removed it. I also didn’t have a spare switch (!!!) for the P60 should it die out on me, so I thought I may as well play it safe considering I couldn’t see the difference with the extra 380mA.
But you must have got a lot of resistance somewhere in the current path. With a linear driver talcap current reading is what the led gets more or less. The resistance could be in the cell, springs, dropin contact to host, meter wires and so on.
The thing has been potted, so unfortunately, I cannot work much on anything else except the underside of the driver and the springs on the tailcap. :frowning:
