EasyB
(EasyB)
11
The coast optic is a two-zone type with TIR on the outside and a lens in the middle. From what I remember it had good beam quality through its range of adjustability, but it doesn’t go as wide as the stock optic. I’ll find some more info on this coast light when I write up the mod.
To unscrew the “bezel” I put the part with the heat fins in a wood-lined vice. There are sort of flats across from each other so you can lock onto it. Then I wrapped the bezel in rubber innertube to get a good grip on it and I was able to unscrew it by hand. Then to unscrew the brass “pill” from the body I used needlenose pliers in the supplied holes.
