Sup folks!
Been reading these boards as well as others regarding headlamps, I really would like to buy one, Ive narrowed down few models and some others Im still researching.
So the question is, Ive found some decent AAA headlamps for cheap and their only drawbacks seem to be use of 3xAAA batteries in separate compartment, whichs is cool, but 3xAAA has as much power as 1xAA battery so Im thinking about buying something like this:
<-And replacing original battery caddy with DIY AA battery holder, would it work? I mean, it should not fry driver or overheat LED to dangerous levels? Given that voltage on my Eneloops is the same across the AA/AAA range, it should work, right?
The reason Id like to do this is simple - I want even longer run times on otherwise awesome budget lights, Im still looking for that perfect sub 20$ headlight and who knows, I might find some great deal on single AA battery headlight, that would be awesome, UF-H2 for example, I wouldnt mind to get that one, I see you folks had group buy for that one some long time ago :D
Anyway, my preference would be great headlamp with external battery case which I could then replace with 2xAA-4xAA DIY battery caddy.
Thoughts? Anyone tried this?!
Will the battery life increase if it doesnt have regulated output?
I should get some brightness increase as well, shouldnt I?
Im craving for Alpkit Gamma, but its out of stock until march, so Im researching other headlights at the moment, lots of tempting models in ~20$ range with only one glaring minus - they all use 3xAAA batteries and not AA! Hence my wish to modify them a bit ;)
