Just an FYI.
Before realizing the Lii 100C I ordered and thought I had received today was actually the Lii 100, I found that the Lii 100 does not fit 21700. Since I received the wrong item, let me ask here – do you have the Lii 100C, and has it been modified from the Lii 100 to fit 21700?
Anyway, here is what I posted before realizing they sent me the wrong one. –
I had the 21700 Littokala 5000 mAh battery in my Convoy S21D. Today the Lii 100C arrived, and I took the Littokala 21700 battery and it wasn’t fitting in the Li 100C, even though on the package is lists 21700 as fitting, and in the website is says
"Five, compatible battery:
*Li-ion/IMR: 22650,**21700,*18650, 18490, 18350, 17670, 17500, 16340(RCR123), 14500, 10440
I double checked the compatibility, then tried to push hard for the 21700 to fit into the charger. finally it went in. When I took it out, the top (positive) was dented in a little, and the wrapper on the bottom was torn.
I really wanted this charger b/c it charges at 2A, which is good for 5000 mAh batteries, both 21700 and 26650. But evidently NOT 21700. shame.
I’m not sure if I now have to replace the dented battery. The 21700 has springs both tail and head, so no problem with that one, but will it work with a light that has a brass contract at the top with no spring? Also, the tear in the wrapping does not extend up the vertical side of the battery, so I assume there is no problem with the tear?
This charger was only released about a year ago. Why would any company put out a new charger that can’t take its own 21700 battery without denting and tearing it, then claim it does on the package? This makes no sense.
