=[LMX Deals]= New Release: Firefly Artemis Z1 Brass
Firefly Z1 Artemis TIR Brass Flashlight.
Discount using my affiliate link https://lmxdeals.com/product/z1-artemis-tir-brass-alloy-edition/
Pocket Rocket.
Introducing the Z1 Artemis, a pursuit of the ultimate 18650 EDC form factor. We engineered the host from the inside out, paring down every millimeter of excess material to achieve one of the tightest structural footprints ever wrapped around an 18650 cell. Then we paired it with the unrivaled Lume X1 driver for absolute efficiency in an incredibly small size.
Crafted for the pocket, engineered for the dark. The Z1 Artemis is a new benchmark for technical EDC.
Special Finishes
Brass alloy material -C86400
Z1 artemis brass edition is made of C86400 raw brass alloy, shinny polished by handcrapt. The hefty weight from such a compact size gives you a special hand-feeling.
Raw brass would get patina as time goes, It is an artwork light with high collection value.
Features
Body Size - 92mm x 26mm x 22mm
Weight - ~112g (without batteries)
Battery - unprotected flat-top 18650 (not included, recommended to use high-drain cells, see below)
RGB Aux under Optics and RGB Auxiliary Illuminated RGB Switch
CNC Construction, Brass Alloy, Brass Bezel and Switch
Open-Source Anduril2 User Interface / Firmware
Lume X1 Boost Driver (32W), Constant Current Regulated (up to 95% efficiency) with UDR (Ultra Dynamic Range)
Automatic Thermal Regulation (45C default), Low Voltage Cut-off, Reverse Polarity Protection
Improved silver-plated Be-Cu Spring System:
    High current plated brass contact paired with a fully compressible positive spring minimizes DCR yet maintains reliable contact and reduces battery tab deformation under shock.
Toughened Front Glass Lens, AR Coated (~97% transmittance)
N52 Removable Tail Magnet
Water Resistance - IPX8
Drop Resistance - 1.5 meters
Included Accessories
1x Stainless-Steel Clip
1x Lanyard
Spare O-rings
User Interface: (Anduril V2)
