Loby600-Moving Head LED-RGBW Wash
Loby600 is designed in a streamline form, which is beautiful and elegant. The light source is made of 4-in-1 high luminance LED, with many features like long lifetime, low power consumption and gorgeous color, etc. You can dim each color LED, change the gray level in a large range. The built-in program includes dimming, strobe, water effect, gradual change, gray level change, and so on. SMPS is used, that makes the lamp weight lighter, the power consumption lower, and the performance more stable. The lamp can horizontal rotate for 540 degree, and vertical for 270 degree. What’s more, it has displacement correction function. International standard DMX512 signal control is used.
This product comes from:
Feature
1.High quality LED light source, low power consumption, high luminance, stable performance, long life.
2.256 dimming range. 16.7 million color mixing, with white light, better effect for color mixing.
3.Linear dimming for 0-100%, flicker free, with strobe/gradual change/color change/water effect inbuilt programs
4.DMX512 control, 4 buttons LED screen display.
I could use that Loby600 light when I read something at night. I can’t sleep sometimes.
Loby600 is for DMX512 control, 4 buttons LED screen display,so please use it with right thing…
