Looking for 14500 Li ion cells?
I have been looking in the forum for a good choice of general purpose protected high capacity, moderate current (~1/2 amp. to 1 A) lithium ion cells to replace old ones. I don’t find an easy answer, so I am positing the question, with the expectation that I may not be the only one interested.
I have AW IMRs for high drain use, but am looking for higher capacity or cheaper rugged protected cells for lower current or intermittent use.
Check the length, though.
http://www.e2fieldgear.com/keeppower-800-mah-li-ion-14500-protected-battery-sanyo-ur14500p-cell/
http://www.mtnelectronics.com/opencart/index.php?route=product/product&path=59_87&product_id=130
http://illuminationsupply.com/batteries-c-48_50/14500-keeppower-840mah-sanyo-ur14500p-protected-button-top-p-953.html#.Uwb22_nPyGs
Nitecore NL147 is good to…
Take a look into the Efest if you haven’t already. OL turned me on to those. I think I now have one of every one they make. So far, they have been more than satisfactory in their performance. Good luck on your search. Keep us posted.
yeah those ones that RMM sells are thick/wide. I can't use them in a lot of lights.
But it has the Sanyo base cell, which I like a lot for capacity.
Width: 14.4/14.3 mm Length: 52.5mm - So I guess RMM corrected the size on his site a while back.
Lithium Ion Battery Comparison Chart: https://budgetlightforum.com/t/-/23822
Just go down the street and pick them up from Calvin at IS.
I have a pair of the NL147 and there very decent batteries. There just not the cell I thought they where.
Might read here for info. what's the highest capacity 14500 cell?
If you get Keeppower cells, make sure it's Sanyo inside. My KP 14500's had DLG cells inside, and the quality is very low. I'll quantify that claim next week when my hobby charger arrives.
