Something that can power an XM-L or XM-L2 at 2-3Watts, can run on one eneloop NiMH, more then 1 mode is nice but not necessary, and i am aware the runtime will be short
I gave up looking for a driver like that and now run 14500 IMR batteries and KD 7135 V2 drivers.
have you tried this one from SB? I have it and it makes a Nichia 219 light up nice and bright. A build from CPF shows it draws over 3A from 1xNiMH on High. I figure a 14 to 17mm adapter can be made from a copper penny, if one were so inclined. I wish I had a light to install it in.
Don’t make me reply with a Simpsons quote J)
I saw it earlier, but it doesn’t say XM-L, though i don’t know what the difference would be
It should have no problems working with XM-L ![]()
That driver will pull 3 amps from the battery, and only deliver 900ma at the very most at the LED. I would think that it would be closer to 600 to 700 ma at the LED. It must convert the battery voltage up to over 3 volts to drive the LED correctly.
I don’t see how this driver can run the LEDs it claims to, they all have differing voltage requirements.
It says it can run the following at 900mA
XP-G ~3.1V
XP-E ~3.4V
XR-E ~3.65V
and the XM-L would require 2.9V
If you are looking for 2-3 watts.
That driver from SB should be fine.
I found this list of pretty much all drivers available, you can change it to your own preferences. This my search for AA drivers, the default page is here
I just scan down the looking at the mA then check to see if its the right diameter and voltage range.
Perhaps you could configure a search to find a better one than I did but the SB was the best I could find in 14mm.
edit: for a single mode you could also think about using a resistor instead of a driver.
It’s a constant current circuit - it produces whatever voltage (within reason) it needs to push 900mA through the load.
Cheers
The higher the Vf of the led, the more current the driver will draw in order to boost the voltage and maintain spec output. I don’t think a nimh will get 900mA as it starts much lower than 1.7V.
These any good?
Marc.
