moviles2
(moviles2)
January 23, 2011, 3:08pm
1
HI all nice forum
I want to find one flashlight powered with 1x18650 for one mod
the inside of the head must be like the "A" type
I want make something like this but smaller powered with 1x18650 and head with 44-55mm diameter
the ultrafire c8 size are nice but not have " A" type head
saik:
someone know some 1x18650 flashlight like the "A" type with 44-55mm head diameter?
I cant find one
Don
(Don)
January 23, 2011, 3:35pm
2
This one might suit you.
http://www.dealextreme.com/p/aurora-ak-p7-ssc-p7-2-mode-led-flashlight-1-18650-12588
The pill is pretty big.
Body and head.
Reflector and pill
Rather expensive as a mod host though.
moviles2
(moviles2)
January 23, 2011, 4:45pm
3
ty mikko but the tr 1200 head are like the "B" type
edit: the mikko post have disappearing??
Match
(Match)
January 23, 2011, 4:24pm
4
Welcome to BLF, Moviles2.
With the head diameter you're looking for, your best bet may be a 2C Maglite. The body can be cut down to 1x18650 size, or you could run a 26650 for more runtime. I know it has an internal head like you picture "A". There may be a host smaller, but I'm not aware of one atm.. .
moviles2
(moviles2)
January 23, 2011, 5:34pm
5
Match:
ty I have some options for 26500/26650 battery size :
maglites
dx sku4700
sku 42672
and more options here: http://www.forolinternas.com/viewtopic.php?f=10&t=910&p=8640#p8640
but im looking for one smaller 1x18650 option
Mikk0
(Mikk0)
January 23, 2011, 4:35pm
6
Sorry. Yes, I suggested tr-1200 body but after a little research, I discovered that its not exactly type A but rather type B. So I removed the post. Sorry for confusion.
moviles2
(moviles2)
January 23, 2011, 4:39pm
7
you have the host and are like "A" type?
this other appears to have the same host and are "B" type
http://www.dealextreme.com/p/trustfire-ssc-p7-c-bin-900-lumen-5-mode-led-flashlight-1-18650-13336
will be hard find one host 1x18650 and "A" type ( if it exist)
Don
(Don)
January 23, 2011, 5:13pm
8
It seems to be the same head as the TR-1200.
I assume you are machining a pill to fit in it - you'd just need to machine a large piece of copper or aluminium to fit. Should give excellent heatsinking.
It is not completely straight sided.
Don
(Don)
January 23, 2011, 5:17pm
9
Can't tell from the pictures but this one might work for you.
http://budgetlightforum.cz.cc/node/1060
moviles2
(moviles2)
January 23, 2011, 8:07pm
10
its a good flashlight
I will ask with private message
edit:
response of private message
huny74:
Hi moviles2 and welcome to BLF!
Sorry, it's more like "B" tapering from 34 mm to 30 mm.
Also the Yezl is quite big for a 1x18650 light.
Regards, Huny
will be hard find it
fishinfool
(fishinfool)
January 23, 2011, 10:18pm
11
Aloha and welcome to BLF Moviles2 and Mikk0!
Nautic
(Nautic)
January 23, 2011, 10:34pm
12
Pictures of pill here: http://www.manafont.com/product_info.php/lunapower-mrv-lg104-cree-q5-5mode-led-flashlight-p-1744
Head is 4.5 cm across
Edit: Just seen thats the head dimensions and not the pill you have made drawing of. So disregard this post.
Don
(Don)
January 23, 2011, 10:33pm
13
I should have thought of that one - I looked through a lot of my lights trying to find ones with a straight-sided head.
Nautic
(Nautic)
January 23, 2011, 10:39pm
14
You know that for a fact Still very fond of it.
But the buttom of the head are tapered, so Im not sure its what his after.
The pill looks exactly like his drawing A though.
old4570
(old4570)
January 26, 2011, 12:56am
15
