After searching on here for a while, I couldn’t find a good 2/3 cell buck driver for one xml that was reliable, had decent modes, and was under 3a to the led.
I am planing to put this in a p-60 style assembly, but larger:
Because of the heatsinking limitations, I am trying to go for a conservative number of amps. It is okay if it doesn’t fit in the driver cavity. no blinky modes is a definite plus.
I don’t know if I am searching wrong, but I can’t find a driver that fits those limitations. A product link would be helpful, but even a arrow in the right direction will work for me.
Those handle heat fine, no reason to limit it. The reflector is beefy and has good contact with the head. You can also make a copper spacer to fill the space between the pill and the bottom of the head/front face of the battery tube.
