After getting a zanflare t1 with the touch sensor switch I want to build a light with one.
Im looking for a touch sensor / module that operates as a momentary / non-latching button that simply interrupts and closes a 2-wire circuit when presses or pulls a single output wire low, leaving it floating when not touched. This is important cause all our current e-switch drivers operate by reading when the switch is grounded and I want this to work with any off the shelf e-switch driver.
I can find non-latching modules that pull their one output wire high when touched and low when not touched but I can’t find any modules / iC’s that do everything we’d need (signal low when pressed and floating when not pressed). Another possibility would be one thay acted like a simple relay closing a 2-wire circuit when touched and you could wire one wire to GND and one to the switch input.
Anyone play with any of these things?
