I’m looking for a for a cheap full/pure flood (no hotspot whatever, preferably) headlight that uses 1x18650 or 1x14500 for under $40. Any suggestions other than the Skilhunt H02?
Thanks
Thanks
Maybe nitecore HC50?
Not trying to sound mean to you guys, but what part of either of those suggestions matches the criteria of “cheap” or “under $40”??
The Sunwayman C22C has a nice pure Floodlight when using the side flashlight and has a regular flashlight at the end as a bonus and uses 18650’s Not bad at all! just get a headband for it
http://www.batteryjunction.com/sunwayman-c22c-xml2-u2.html
Review
The Sunwayman C22C sounds perfect, thank you. Fastech is selling it for $40.77. What a unique light! A max output of 180 lm for the flood light is adequate for my needs.
the HC50 is selling for $42 on fasttech, so close enough ![]()
You won’t like it since it has relatively intense hotspot. I don’t like to use it for my close up works. I use HC50 more for general, medium range seeing, trekking, etc… Try put a scotch tape on its lens, really helps.
For work, so far my Spark SD500CW pure flood is still the best. But, it has no low battery warning. When it’s done, it’s shuts off immediately, not good…. ![]()
