Hi!
A ForoLinternas fellow is looking for a driver for replacing his defective XP-11 circuit.
He has posted this pic of the defective driver:
any ideas of a replace driver that will work with this kind of switch?
thanks!
Hi!
thanks!
Not clear to me what size the driver is, but perhaps our own DrJones could help? http://drjones.dyndns.info/
I second that. If a 17mm Nangj 105c will fit (and it looks like it should from your pic) then you can select from the list of DrJones drivers.
My favorite is Lumodrv… it’s got a great interface: hold the button down from off to start at moonlight and ramp up. double-click for max, triple click for 25%. Clicking and holding when on ramps brightness up or down. The driver also has a battery checker and even momentary mode, and you can even reprogram the settings if you want. It’s awesome! Far better than the driver that came with your light. I have lumodrv installed in 3 lights right now.
To buy a DrJones driver with his firmware send him a private message here on BLF. He’ll get you set up. ![]()
Richard and Mountain Electronics also sells a driver compatible with an electronic switch with some customizable options, but since you’re in Europe, DrJones is probably the fastest option for you.
The driver nor the defective flashlight isn’t for me, so I can not comment on the driver size (but I guess it is 17mm), and the first thing I told him was a reprogrammed NANJ 105c. He is looking for a stock driver.
Let’s see what he thinks about ordering one from DrJones or keep looking for a stock replacement driver.
Thank you guys!
A stock driver? ouch! I don’t know of anyone who sells a stock electronic switch driver. Even if one could be found, I’m pretty certain that a DrJones driver is probably VASTLY superior in features and interface.
No doubt, but let the guy decide ![]()
Thanks!
I've mod'ed a couple of these XP-11's, just need a e-switch driver. For mine I did at 3.5A and Dr Jones lumodrv, but also am using the MiniMo, but will be switching to Jon's STAR e-switch driver. RMM sells these pre-installed.
