but I`m looking for a driver that has about the same group of modes, but without the 5-sec Group Mode setting.
Sometimes I accidentally enter this Setting without wanting to.
IOS sells the Qlite Rev.A which is pretty close to what I want.
That driver provides 3A, which i don`t really need, so something in the 1.5A area would be nice.
Where else are these kind of drivers available? (4-5 modes) (either is fine)
4; Very Low, Low, medium, high
If you want a steady supply of drivers and not just one or two, pick up a SOIC8 programming clip, a USB ASP programmer, and flash them with DrJones' Nlite: https://budgetlightforum.com/t/-/18531
It works on any of the Nanjg-based drivers that use the ATTiny13 controller (edit: as long as they have the bridgeable stars to set the modes). You don't have to write any code, just paste a string of text into a command window and it's done.
Okay... that could be worth having, some links please for the stuff you mentioned? the clip etc...
edit: I found the clips at FT, 2 versions...which is better?
edit 2; if anybody knows where these drivers are available, please link.. The option for programming it by yourself is nice, but I probably would prefer a no nonsense pre-programmed driver.
clip: search for 'soic8 clip', I imagine you could find one local much easier than I, here in rural Mississippi USA...
software: http://winavr.sourceforge.net/ - that installs a bunch of tools, for flashing Nlite all you need is to paste a string into a CMD window opened in the folder where the nlite.hex is saved (in Windows, hold the shift key & right click, hit 'open command window here').
