Looking for a light for my Picky kid
My son tasked with finding him a EDC flashlight and has pretty specific needs/wants, so I thought I’d ask for recommendations here:
  1. Is able to use an 18650 battery with built-in USB-C port.
  2. Comes in a color similar to OD Green or Coyote Brown
  3. Is very waterproof
  4. Pocket Clip
  5. Has low output Red mode
  6. Easy to use UI
Maybe a Skilhunt EC200s w Red?
Non Black Color option is limited to Gray. They use 69mm protected cells, so probably a 70mm USB cell will fit?
Dont know how waterproof they are, there is a USB port with a rubber flap cover. The lowest Red is 3 lumens, 630nm.
I should have mentioned we’re looking for one without a USB port to reduce the chances of water getting in.
I don’t know flashlights (as a whole) well enough to give such a specific recommendation, but good luck in your search! :+1:
Look here my best “resistor” friend😌
A little help for you
understood, but I cant think of any dual channel lights without USB, except Hank lights, and they dont take USB 18650
another thought
I have not disassembled a Skilhunt EC200s, but mine has the USB very closely fitted, there is no gap around the socket. Maybe there is even an O ring to seal it, dont know.. Maybe you would be happy with the waterproofing as is, or, maybe you could seal the rubber flap over the USB port with some RTV?
(thats the 18350 model, guessing the 18650 version is the same)
Thanks, I sent it to him as an option.
I wish the 18650 version came in Coyote.
Wish wish wish they had used deep red on the ESKTE.
I don’t see a option to choose a light with a Red mode.
i am confused.
is it the Battery with a USB-C port or the Light?
Battery
Why doesn’t he use a 21700 based light with an 18650 protected battery with ubs-c. These 18650 battrries are 70mm long and would fit in a multichannel 21700 light of his choice.
They also make adapters (or he could McGyver something) to increase diameter of 18650 batteries to eliminate any potential rattling.
He’s going to be carrying it around in his pocket for EDC.
All options are not available but you can mod the model you find :relieved:
So my son decided to give up the Red mode for now, so I built him a S2+.
It was Black but I baked it in the oven to get it to turn brown and I also added a heat treated SS screw on clip to finish off the look.
Before:
After(The tailcap is a different shade of brown, it must have been anodized in a different batch or something):
Nice result!
I believe that red may be good for not attracting bugs, but my experience has been that white moonlight is just as good for preserving night vision and is available on most lights.
