I have decided on what type of light I would like to purchase next and would like your suggestions.
I want a light with a mix of flood and throw the most important thing is output,……I want to turn the night to day!!! :bigsmile: To better describe what I want out of the light imagine standing at the base of a 100’ tall tree,…I would like to be able the light the entire tree from 15’ to the top including branches.
As of now all lights will be considered,…price, battery format, customs, size ranges, multi leds, …… no limitations.
If you can afford it, the Fenix TK75. Another one is the EagleTac MX25L3 (I really like the tint and beam on this one). Keep in mind that these lights are more pricey and this is BLF. If you wish to step up even more, you can check out modder Vinh Nguyen. He can mod the 2 lights I mentioned as well as quite a bit of other ones.
I have read and watched some videos on the TK75 and it is a very powerful thrower but inside of 100’ I think the throw will be wasted? It is also very $$$$$!!
Since you mention no limitation on price I would recommend you Supbeam X60vn. :bigsmile:
Ok, be serious. You said TK75 is expensive for you so please let us know your budget’s upper limit?
BTU Shocker in stock form is very good itself though it’s heavy and requires two hands operation. It is $120 now without discount, maybe you can look in Wallbuys or Banggoods, they have promotional coupon code from time to time AFAIK.
Yeah, a light in the super thrower class would pretty much be wasted at 100 feet. The beam concentration is actually a bit blinding within 10-15 yards.
I like the idea of the 7xml2 SRK with a few emitters dedomed to give additional throw while maintaining good flood. I’m sure someone here would be willing to mod that for you. At 10A you’re looking at a hand melter within a few minutes.
Really though, an SRK should be fine in stock form for 100 feet. My 3xml SRK performs decently at 30 yards and it is average/slightly below average compared to other stock SRK’s.
Electrolumens Kong-21. It looks like they are normally built with a throwy carclo lens, but there's no reason you couldn't have it built with a less throwy carclo.
I really like the J18 over the Skyray King or Kingx7. J18 is brighter, and not very much more expensive at about $45-55, with reasonable 3x Trustfire 26650s it stays on for longer, and it doesn’t get hot enough to burn your hands (unless its a very hot climate). But if cost is no issue and you don’t care about carrying something even bigger, the Shocker is probably a good choice! The 15x or 18x lights I’m sure will output a slightly larger amount of light but wont throw as well.
BTU shocker, while probably my favorite light, is going to be wasted in a 100 foot environment much like the tk75. Both are a ton of overkill in the throw department.
The 15xml lights, at least the ones I’ve seen, are not worth the money. And you would spend $100+ upgrading the emitters to xpg2.
You could, but for what he’s talking about, a stock 12x or 15x with no mods will throw more than he asked for, if you don’t mind a big light its a good choice. I just think J18 is most efficient: about half that price, and still more than enough throw and output to wow. I just took mine out last night again with fully charged 3x 26650 KingKongs, first time in a while, and did exactly what he is describing for fun There was a lot of moonlight out, so using it as a “tree candle” to light them up was fun After using only 1200-1600 lumen lights and SRK the past few weeks, it was again impressive.
I have both J18 and a 15x, and while 15x is brighter, its not really a “wow” difference between J18 and 15x, probably because the my 15x has a wider distribution of light, and a ringy beam.
What you are talking about would be an interesting light but I’m pretty sure just the mod would more than double the cost of buying the light AND the batteries together!
I guess I am looking for a flood light with a little throw,…150’ max distance with a very wide usable spill. The Shocker is a front runner but I am worried about it having to narrow a beam?
What about one of the Sky Ray King type lights with some modding? Say I purchased a Sky Ray Type light and sent it to one of our modders along with a $100 bill,…could they beat the Shocker?
