I’m looking for a light matching a particular description.
Essentially I want a Convoy M1, but one that takes a 26650 (or preferably 26700). I have seen some offerings from Supfire, but none with an OP reflector.
All the electronics will get swapped, so build quality is paramount.
Sounds like you want the Trustfire A8 that Rey created a BLF version of for us a couple years back. Superb build quality and easy to modify. IIRC it had a MOP reflector, too.
$25 maybe a bit expansive for a host, but I am sure it will make you smile when you throw in a FET with XHP or MT-G2. Next closet candidate will be Shadow JM30/35.
SMO => OP is done successfully in some different ways. O-L has been known to spray clear-coat onto SMO reflectors to make a light OP without losing too much reflectivity.
Well, it is clear coat, so at bestworst you could peasantly screw it up! In other words, I don’t think you could make it unusable if you tried. But, then again, I could be wrong! J)
