It kind of fudges on the first one but with the reflector unscrewed it turns into a directional candle. The XP-E is miniscule and this thing throws way more than a light its size should. Fasttech have them too, but no box, Focalprice is the only place that hasn’t been put on the verboten list that I’m confident comes in the original box.
I’m not sure if firefly mode is the same as the Solarforce Moon mode but check out the SolarForce Z-1 and Z-2. I have the Z-1 and am completely blown away by the light that comes from this tiny package with a XP-G2 LED. And all for $15.99. Plus the current deliver times from HK are about 8 days to the east coast.
fenix makes some good lights. i have a pd30 and got my dad a pd32 which came with a clip. they run on 2 cr123’s but fenix makes some single 123 lights and AA lights too. I have had mine about 5-6 years without any problems even after going through the washing machine, dropped, and in the Texas heat. I’m not a big fan of the additional side button on newer versions but you should be able to find some pd30’s or pd32’s on amazon that were the previous version. also, don’t let the cr123 prices discourage you…. they can be bought online for $1 a piece from battery dealers selling tenergy and titanium brand batteries
Item Specifics
Brand Xeno
Model E03
Lightbulb Type XM-L2
Tiger E03 v3
100% Brand New, Original XENO Product
· Anodized AI-Alloy Construction
· GFC (Gamble Free Concept) Impact-Resistant System
· HDE Engine-XENO unique Quiet RSLTM LED driver
Linear LED driver, Not PWM mode
Non-Flickering and Absolutely Noiseless even at Ultra-Low level
With Ultra-Low output, more than 20 hrs burning time
· CREE XM-L2 T4 (Warm White 3250-3500k) Max (OTF) 420 Lumens
· 6-Stage Variable
Normal Output: Low, Ultra Low, High
Hidden Output: Strobe (High) + Locator Beacon + Strobe (Low)
Ni-MH battery:
Low (150mA/45lms/4hrs), Ultra Low (20mA/20lms/20hrs), High (420mA/120lms/1hr)
Li-ion battery
Low (1A/200lms/45mins), Ultra Low (300mA/80lms/2.5hrs), High (1500mA/420lms/20mins)
Low output is always the start mode after 3seconds power-off
· Voltage range :0.8~3.7V.
· RAAX, micro OP for XM-L2 series LED
· High Quality toughened mineral-glass lens, precision polish for impact resistant
· Powered by 1x AA size battery (Alkaline,Ni-Cd,Ni-MH,14500 Li-ion,LiFePO4)
· Grow in the dark silicone rubber tail cap and O-ring under lens
· Built-in battery inverted-load protection.
· 10 meters dunk resistance
· Size 96.5mm x 21.5mm x21.5mm
· Weight 1.7oz(48g)
Package Includes (with original packing):
· XENO E03 Tiger x1 (Red)
· Spare Switch Module
· LS550C Lanyard
· Two O-rings
