I’m looking for a flashlight to use it mounted on my airsoft replica.
What I was looking for:
–18650 or AA battery
-EDC size
-NO glow in the dark parts
-around 20$ price tag
–700lm min. brightnes
And less obvious:
-Remote tail switch
-separate mode select button/ring/whatever (I cannot work with standard half press to swap mode, and standard memory modes as sometimes I need specific mode to be accessible without turning on a flashlight)
Not sure you will get all that the for $20, a good remote pressure switch will cost that. The one I have on a rifle cost that and it’s not even that good, it’s well made in parts but quite fragile .
I’d probably look at pressure switches first, then choose a torch as that will limit your torch choice, switches for the c8 and the 501 type torches are available for a few dollars, then Yourll need to find a single mode torch or mod it so it’s single mode, so you don’t have to cycle through the modes and blinkys.
You could even make a pressure switch, plenty of how to on the interweb
Makes it easier and gives you more choice as you don’t need a pressure switch.
There was a seller on ebay selling off sunwayman torches fairly cheap, got a Sunwayman v20c from them, but still a bit more than your budget, but a good torch with both a tail button and ring selector, don’t know if they have any more.
Maybe have a look at dive lights, I got one from tiny deal or one of those type of sellers in one of their flash
sale’s, had selector ring etc and used 18650, not the best torch in the world, but ticks all your boxes and was less than 15$, probably ok for putting on an airsoft gun
