I'm looking for a AR lens with a minimum diameter of 63mm in diameter for an idea in my head. I will also need an o'ring to suit around 1 to 1.5mm in width.
G’day mate,
If you can’t find one readily, give Chris at flashlightlens.com a go - he can custom cut one for you in the diameter you need.
I’m waiting for a 93mm AR lens from him, which should be arrive here in SA soon. The 93mm one costs under $15 US delivered … so your 63mm one should cost less. Sure its more expensive than the small cheapie ones from China, but for the size and AR/glass quality it is worth it.
Good luck in your search mate!
Cheers
Thanks d337944. Sounds like a good option.
Top notch service from flashlightlens!
You can easily join o-rings with superglue if you cant find the right size…works a treat!
Woody
Thanks for the hint Hopback. I've been doing the trick with super glue and longer o'rings for awhile much to the kids disgust. They are the ones with the super glue. Sharing buggers they are.
I am looking for a 57.5 mm lens for HD2010 and can’t find it anywhere!
