I’m looking for smaller dual (or more) LED headlights with metal casing with separate 18650 case. I am not interested in bike lights put on the head, I need them slim as I use these for climbing and caving. I am looking for candidates for mods like I did with this one: https://budgetlightforum.com/t/-/47012
I’ve seen the Olight HS2 in this thread: https://budgetlightforum.com/t/-/47022 but I’m not to fond of the button solution. I might give it a go though, it’s a real slim host.
This headlamp doesn't have separated battery, but it's not plastic,and price is great. I have single LED version, quality of host is similar to Convoy.
Target is independent flood and throw beams, just like the mods I linked in the OP. In some cases I might use a triple or quad instead of throw (like my HP25R mod). I’m looking for good host candidates.
Take Carclo 10621.
Make half of it frosed with sand paper.
Take two XP-E2s.
De-dome them.
Take two XP-L2s.
Use dsche or tpad quad board.
Put xp-e2s under clear half of the optics.
Complete with one of your custom drivers.
Enjoy.
Hmm, not a bad suggestion at all. But the quest for hosts still remains, except I’d only need one LED. Sure, I might try one of those hosts that also houses the cell, but I still think I’ll be going for a battery case on the rear. The slim HP25R is so far my favorite but it’s pretty expensive.
Biggest problem is that most of cheap headlamps are not moddable. Once I wanted to change led is such cheap light with glued glass and tried to warm it up with hot gun - suddenly glass melted (it was plastic) and I couldnt find suitable glass to replace.
So I would specify your search in lights with easily removable bezel and lenses.
Thanks. The Spark SX5 might not be cheap, but it’s cheaper than the HP25R.
Ultimately I wanted to design my own headlight host but after a little research I found that it will take far too much time and money. I think I’ll stick to butchering existing lights for now.
