Looking for good batteries and charger
Hi people,
I’m fairly new here as I just got myself a Nitecore P12GT. Now I am looking for the best bang for buck battery.
I am a bit puzzled, there’s so many to choose from and also various sources and I am not sure what reliable sources are. Bit afraid of fake capacities.
I also figured out as I am a beginner, I should go for protected batteries.
Was about to order 3400mha Keeppower from nkon.nl for about 12EUR/st.
Then I ran across these, for about 5EUR/st:
http://www.gearbest.com/batteries/pp_187046.html
Are they just as good?
Or what batteries would you recommend me to get, what gives me the most bang for the buck to get me started.
Of course looking for a charger too but I guess that will be a Xtar VC2. Or any other recommendations?
Thanks in advance.
I bought them, the capacity is in my charger 3300mAh from 2.8V
They are original Panasonics
The PCB is good
Thanks. Will order those then :slight_smile:
There is no reason to use protected cell in a single cell flashlight with built-in low voltage cutoff.
Assuming you also use a decent charger, of course.
The best cell for this light would be Sanyo NCR18650GA, available from both NKON and gearbest.
Are you sure? Can’t find any specification about low voltage protection.
Have yet to order a charger but it will be a xtar, seems to have the most bang for the buck.
There is no reason to use unprotected high drain cells for a flashlight draining less than 3A
The P12GT can only use cells with button top as it has mechanical reverse protection
Most unprotected are flat top, so those wont fit
The P12 reduces current continuously and cut off at about 2.8V
As unprotected are shorter and thinner they rattle in my P12, fixed that with tape and soldering a button top on the unprotected cell so it contacts
as well as adding spring bypass
But for a normal user I recomment no experiments
I use flattops in my p12gt. I only have a couple button tops. Hg2 work, 30q, ga, laptop pulls,NCR b flattop, mj1, only one flat top cell won’t work and its because the flat top got pushed in from my vaping device.
You guys confuse me….
From what I found is that the NCR18650GA currently the cell with the highest capacity, right?
Also I read that the NCR18650GA has semi-buttontop and that it will fit fine in my p12GT.
So for batteries for my p12GT it comes down to NCR18650b 3400mAh Protected vs NCR18650GA 3500mAh unprotected.
@lexel, you say no need to use high-drain cell, but are there any other cells with greater or equal capacity that are mot specifically high-drain as you pointed out that i’’m 3A but most cells do 7+A
shipping kills it for me $12??
dikzak - I believe these two are both giving you good info, just they have different criteria - and yes it is confusing.
Protected cells will cost more. Single cell lights are less at risk than multi-cell configurations. Low voltage cutoff further reduces risk. So why pay more for your cells?
Often the protection on protected cells will cause it to not support high amp lights, but yours isn’t a high amp light. No need to skip the protection.
Sure there is - unprotected NCR18650B or NCR18650GA are half the price of the protected versions.
And if the flashlight and charger already have protection built-in, there is no reason to use protected cell (in a single cell flashlight).
Both will work great. Don’t sweat it. I personally would go for NCR18650GA as it is a newer and in every way better cell (I have both NCR18650B and NCR18650GA).
Thank you very much guys. That made it all clear. Went for the protected NCR18650B, as they were cheaper incl shipping than the unprotected GA’s.
I think that was a good safe, economical move.
For the Future: A couple of things to remember you will likely get other lights and you may want to use your batteries in different lights with different requirements so it’s good to have a few different options. The GA cell is really great. I use it protected and unprotected. US pricing is <$6 for the GA unprotected and <$10 protected. If the unprotected GA cell works for your application then I think it represents the best bang for the buck. As you get started you will find you have to navigate length issues and diameter issues with different batteries and some lights.
You’re all set now though and hopefully you like that light.
Flat top unprotected cells do not work with P12GT.
Mechanical protection (plastic ring around positive contact) will not let flat top battery to make proper contact.
It will rattle inside battery compartment like crazy.
P12GT is made for protected 18650.
