Fulgeo
(Fulgeo)
9
Convoy M21A 5000 K version. I have two of these and the tint is about perfect on the two highest settings (100% and 30%). This light is a thrower but has a larger hot spot.
Convoy S21A host. Use a Cree XP-L2 (I would use a 5000 K tint) or in my case I used a XP-L HI V4 3C. Drive it at 3 amps. I used a 105E 20mm 7135x8 driver with guppydrv group 20. This give you a wall of light with some throw. Driven at 3 amps it will get hot after a minute of use, but stepping down to 33-50% it is very useful and can be sustained until discharge.
You can change most C8 throwers into flooders by swapping out the reflector to an Orange Peal reflector. Pardon me if I was stating the obvious as if it was inspirational.
As someone helpful said “Good Lux!”
