Looking for Neutral White High CRI Alternative to my Eagletac DX30LC2
I’ve had the Eagletac DX30LC2 for probably 8 years and I can’t find anything to replace it yet.
What I like about it is
  • Thin 22mm tube (No larger head, no protuberances on the tube. )
  • Good throw
  • 2 - Button operation, direct and easy access to high and low.
What I don’t like is the color temp and CRI of the LED in it.
I tried a Convoy S6 but it’s noticeably thicker and while I can set it up to be the highest mode first there’s no easy way to also access the lowest mode.
Not modded an eagletac before, they’re probably glued so perhaps a slightly tricky first LED swap if you’ve not done it before but might be worth a go? Swap in a warmer XPL-HI or perhaps a de-domed 519a ?
I’m not that skilled sadly
Bring both lights to some handy man and ask to swap leds.
Tried on Paramatrek, not many options, seems the eagletac lights are surprisingly narrow for 18650 cell lights! I upped the diameter to 24mm as all that existed at 22mm was variations of your light.
http://flashlights.parametrek.com/index.html?battery=1x18650&switch=all,side,tail&bezel_size=,24&body_size=,24
If you’d like a DX30LC2 w/ SST20 R9 CRI95 4000K, they’re available new in stock (2) @ illuminationgear. I have that emitter in several Eagtacs, and I find the ones they use to be particularly nice examples of an SST20.
That’s perfect.
