Low output P60?
Recently picked up a el cheapo plastic p60 host with a recent order from illumn which would make a GREAT toolbox light (cheap, durable, cheap…) as it runs off lithiums and would tolerate the outdoor storage great. Is anybody aware of a LOW COST P60 drop in which would offer 30-50 lumens of output in a single mode set up?
Is this one of the Solarforce ones? I regret not getting one of the nice yellow ones when they were available.
Back in the day the normal thing to do was roll your own P60 drop in. Take a “P60 shell”, LED emitter, and driver of your choice, add solder and thermal paste, job done.
My P60 parts used to come from FastTech, who have now closed down.
Kaidonain seem to do the body, reflector and spring as separate items (???)…
Your challenge nowadays is finding a nice, low, single mode driver that’ll work with the 6v you intend to use… if I remember correctly, these things take 16mm diameter drivers…
Alternatively, for a real nostalgia kick, Kaidomain also does a 6V Xenon bulb drop in!
What is the input voltage of a Qlite driver, and would it be horribly inefficient at 6V? Mtn could probably make one custom with single mode, 10% output or something like that. Lots of members could build it for you or if you could solder it, a fun project.
This seems like a good place to ask: could you run a 6v incan drop in from a single 18650 with a 6V led driver? I’ve been considering picking up one of the kaidomain p60 hosts and the 6v dropin seems the one to go for, but it requires 2S input and I don’t fancy the size of 2x18650 or buying 2x18350 I don’t have any other use for.
How much current does a 6v incan bulb draw?
I hope this drop in suits you.
No info on the output but I don’t think this is very bright.
Why 6v led driver? I’m not sure how you’d put an LED driver into the xenon P60 drop in…
Best would be the single lithium ion (3.7v) dropin they do, the wattage is something like 10w? So current of 3A…ish.
Good spot on the current, thank you.
Chicken Drumstick has a very good comparison of the two xenon p60 dropins here:
It seems to me the “9v” one is the one to go for, but I’d rather not use 2x18350s.
I have a compact bench power supply on it’s way, I may buy one of these 9v xenon dropins and investigate building/adapting a driver for it. I’m sure I’m overcomplicating things here but that’s half the fun!
