I’m not worried so much about the heat of the LED, I know the light is capable of handling it. My main concern here is the heat being dissipated by the 7135 regulators themselves.
For example…
Let’s say I’ve got a fully charged 4.2v cell and I’ve got it set on a regulated mode that is drawing 3 amps
The VF of the XP-L2 is ~3.2v around that current range, and there will be some voltage drop from the battery being loaded so lets say the battery is spitting out 3.9v
0.7v difference that has to be dissipated through the 7135 chips 0.7v*3amps=2.1watts of heat which seems a bit high to me for the driver PCB to dissipate since it isn’t as thermally bonded to the head as the LED is.
I could be completely wrong on all of this, I guess my worry is can the driver/7135 safely dissipate that much heat without damage?
This may not be a problem since it is being spread over multiple 7135’s, what brought about this thought is Texas_Ace’s footnotes on the “17mm V2 Texas Commander” driver on his OSHPark page.
https://oshpark.com/profiles/Texas_Ace/page/1
But, from my understanding this driver uses a single CC IC to do the regulation, hence it may be more of a problem in that type of setup vs multiple 7135’s.
