Low voltage protection (LVP) prematurely triggered - solution: clean the flashlight threads
I have an issue with one Convoy light, my EDC.
As far as I know, my other Convoy lights do not have this problem.
My EDC is the Convoy M21E with an LHP73B emitter.
My EDC prematurely triggers the low voltage protection (LVP).
I use a Samsung INR21700-50S cell in my EDC, and I use my EDC at 40% of 10 amps.
I have tried several of these cells, and the light always behaves the same.
When LVP is triggered, I take the cell out and charge it.
My Vapcell S4 Plus tells me that the cell is at 3.9 volts (or higher) when I put the cell in the charger.
This is quite annoying because my EDC has very little runtime before LVP is triggered.
I am not a modder, so I think my only option is to order the same light and hope that the new light doesn’t have the same issue. :man_shrugging:
I had the same issue with Convoy and cleaning all the threads solved it. Not sure if the same reason here but worth a try.
Thanks!
I’ll give it a try and report my results in the future. :grin:
Great advice!
Additionally, several other factors could be at play:
  • Chargers are terribly inaccurate at reporting voltage–I would only trust it to +/- 0.4V. Use a multimeter for reliable readings.
  • Cells sag under load. Even 4A can be a nontrivial load for a cell below half-full.
  • If the ambient temperature is cold, voltage sag becomes much more prominent.
  • The above factors are made worse if the cell is old. I’ve got some old high-current cells that activate LVP at a true 3.9V at around 20 degC ambient, under 4-5A load.
Man, I thought I was losing my mind. My S21E had its LVP kick in at 50% capacity and it was driving me nuts. I will try cleaning all the contact points.
I was being conservative with this number.
The voltage was at 4.0 or higher either most or all of the time when I received the LVP.
Also, my flashlight used to flicker every now and then.
I cleaned the threads five days ago.
I got the LVP just now and put the cell in my charger.
It was at 3.61 volts, which is a huge improvement.
I got a lot more runtime, and my flashlight has not been flickering like before. :heart_eyes:
