Greetings All,
I stopped by Lowe’s recently and saw an interesting LED 12VAC landscape floodlight on clearance…
I thought it could make a dandy light for use on my small boat, for avoiding crab pots and other
miscellaneous hazards.
The package states “14 watts” and “1100 lumens”. Inside the aluminum housing, there’s a
small board with a bridge rectifier and an MP2480. It was putting out 6VDC to the LED array.
Apologies for not getting the pics to appear here…clicking the pic icon seems to open them up,
on Flickr.
I had several eBay LM2596 voltage regulator boards laying around, and hooked one up,
set to supply 6VDC…
It works great—for about 15 seconds! Then, the LM2596 heats up, and starts blinking
the LED array.
I’ve got a couple of questions here, in trying to figure out what’s not right.
1. The propaganda on the eBay voltage regulator board suggests it’s good for up
to 3A without heatsinking or other heat-abatement; the Lowes carton describes the
LED lamp as ‘14 watt’, or about 2.4 amps at 6VDC. So, nominally—given figures of
possibly dubious validity—the eBay board sounds like it could supply the LED array.
Do I just need to add a heatsink to the existing board, or get a board with higher
amp capabilities?
—and—
2. I understand LEDs require some type of limit on current; with the resistors mounted
on the LED array, is the current-limiting issue taken care of (or do I need to use a voltage
regulator board that provides ‘constant current’ control)? Is the LED array trying to pull
way more than 2.4 amps from the eBay board?
Thanks for comments, criticisms, suggestions, etc!
