Lumintop Copper AAA Tool (XHP50 fun)
Hi all,
This build is just for fun, I was experimenting to see how far and how small you can push a bright light in your pocket :bigsmile:
In my previous T10T thread here (MT-G2 Thrunite T10T Ti "Micro Sunbeam"), i put a MT-G2 into a AA sized light, powered by 2 x IMR 14250 (half the size of 14500) running a 12mm FET driver, the output was fantastic and was actually usable day to day
This time, I came across the Lumintop Tool AAA in Copper, so just to see how far I can push the size/brightness factor in a small light, I plan to put in a XHP50 in the AAA light
A light of this configuration is possible due to the entire light being made of copper and the whole light acts as a heatsink, allowing heat to be drawn away from your hands
Here is the light in stock form
The light broken up into its parts
The pill seems to be thread locked, a little heat needs to be used to loosen the threadlock, I used a lighter blowtorch to heat the head of the light, which eventually allowed it to be unscrewed
The heat transfer is excellent, just for fun, I screwed back all the parts together, and within seconds the tail part itself got warm and the head became colder till it was able to be handled
Heres the pill removed
With the star and driver removed
I filed a XM noctigon down to size and removed the “rimming” of the pill so as to allow maximum contact between pill and star
The driver itself has been reused just as a contact board (I ran out of 12mm FETs), it needs to be filed down to size to allow 2 wires to go through, these wires are drawn directly to the LED
This is the whole stack
The reflector needs to be slightly enlarged to allow the XHP-50 led, after assembly, the light fits snugly
How do we power the light? Using 2 10180 LiCo (Lithium Cobalt) batteries, as the battery is slightly less then half of a 10440 battery, some “spacers” needed to be used
The light is definitely bright, apparent brightness is brighter then the T10T MT-G2 light previous, but it is probably due to the cool white tint compared to the neutral white of the MT-G2
Seems to be a donut inside
However, probably due to the cells it is not able to handle the current for a sustained amount of time, hence just within 5 seconds the light will dim, making it usable only for signaling purposes (which was what i had intended), it makes an excellent camera sidekick due to the extreme flood
Day to day use? Probably not really useful since it becomes dim after awhile, but it makes a excellent blink light, and the heat sinking is excellent
I am waiting for some more 12mm FETs to arrive, I will probably pop one in when it arrives to see how usable it is
Joining the rest of the exotic family lights
Cool
Man you’re one crazy modder
You are a bit of a mad man. Congrats on sharing some of your madness with us. That is one sweet family shoot you got there. :)
Heh I’m just playing out my hobby… I’ve always been fascinated by small flashlights, as the mantra goes, smaller, brighter, better :bigsmile:
But this seems to be the tipping point, the Lithium Cobalt batteries are not designed for high drain, so unless I can find IMR sized 10180 cells, I don’t think its possible to make the output stable and brighter… Furthermore, the capacity is only about 90mah or so… not really usable on a day to day basis…
I’m planning to switch it to a xpl-hi instead with a FET and efest IMR 10440 battery, might turn out brighter and better and more usable and hit 1000 lumens…
very nice!
runtime? 3 minutes? lol
this is madness :bigsmile:
Haven’t tested it, probably more then that, given that it dims considerably after a few seconds… if it continues to dim, probably could last awhile :bigsmile:
Of course it’s madness! But the kind of madness that I like. In a large light performance is relatively easy and somewhat less impressive to the unenlightened, but when they shield their eyes from the bounce that comes from something this small, the peanut gallery is highly impressed. And that’s what brings people into the hobby :bigsmile:
Phil
Very interesting mod.
great tiny work!
Umm… about your cells… You can get 90mAH cells that can push about 1.5A or so, depending on the Vf of the emitter. You’re losing a tremendous amount through that stack of magnets! :open_mouth: Get a piece of copper to replace that stack of magnets, and I’m sure you’ll see a noticeable increase in output from the light. I know these things from my own playing around with Veleno Designs 90mAH 10180 cells. At first, I used a stack of magnets as spacers and they got REALLY hot!
Edit: By the way, what bin is your XHP50? If it’s at least a G4 bin, you’d have over 1000 lumens at 1.5 amps! If it’s K2 bin, you’d have close to 1500 lumens!
Hi David, I took your suggestion and wrapped the magnets in a coil of copper wires, brightness appears to be the same, I did a measurement using a mutlimeter, it on power on it starts at 2.4amps and rapidly drops to about 0.6amps and stays… it still drops and the cells get a bit warm, the light gets visibly dimmer each second it is powered on
Either the LED is overheating and dimming (which I doubt since the star is not that hot) or the cells are giving up
I guess its a limitation to the cells, I’m not using the veleno cells (though my dealer has them), may borrow his cells to test, but these cells weren’t meant to endure such high drain, so unless we can find some IMR cells i guess this would be the limit for now, the IMR half AA (14250) cells are surprisingly very good, and can put out sustained wall of light without dimming
So i guess for now I will be focusing on single AA 6v builds, I am already planning a AA XHP70 build soon…
In this case, a single XPL running direct drive off a 10440 might be better, if not brighter in the long run
Wow! 2.4A at start? That’s actually very good! And, it’s probably the reason it’s dropping so fast, too. When I measured mine, I used a cheap DMM with 12ga leads in series with the cells, feeding to a string of emitters in parallel. So, the DMM was probably actually limiting throughput a little, while the low Vf of the string of LED’s helped it reach a sustained output level for a little while. I didn’t hold it there long enough to see when it dropped, though, since I was afraid something might burn up in the process.
Wow, nice work on your Tool there! A real pocket blaster! They are a dream to mod despite their diminutive size. It’s possible you exceeded 1500 lumens for the first few seconds there. It’s a shame that the copper Tool uses what appears to be an aluminium pill tho.
Yeah, but due to the extreme flood it does not appear as bright as say, a 500 lumen focused light (with big reflector), the wow factor is when you shine it up on the celling and the whole room lights up from a seemingly empty hand :bigsmile:
I’ll probably try the veleno cells instead and see what happens
Hmm yeah I was a bit disappointed when it came out with a aluminium pill, but I (somewhat) mitigated the problem by flooding the seams and copper star to the walls with silver thermal paste, the light gets hot, but due to the dimming it somewhat balances out,
But its definitely bright, I can literally feel the heat coming out from the front of the light, its good for flashing, the few miliseconds it remains on is like a camera flash with not noticable hot spot
