Hi everyone! I am new to flashlights but have been an avid modder/tinkerer in various fields for years. First let me introduce my first "Serious" flashlight and some mods I have started working on: Copper EDC18 XPL-HI 5000k NW
Installed Carclo 10507 optics
Increase in brightness and throw is significant. I had the 10507, 10510 and 10511 optics so I also messed around with the rest of them before settling on the 10507.
Cut Glow gasket out of diffuser
I would recommend this to anybody who wants a decent glow gasket but does not want to spend on actual turboglow/can't get their hands on one. The gasket cut out of the free diffuser glows much brighter and longer than the free Lumintop glow gasket. I find the free glow gasket contaminates the spill's color while the DIY one does not. The free glow gasket is so disappointingly dim that I took it out an hour after playing with it.
Squishy diffuser is still perfectly usable with a hole on top, in fact I prefer it this way as I get a diffused ring of light and a usable beam at the same time.
Designed and 3d-printed a fire-shaped diffuser in ABS
This was my first flashlight with candle mode so I was pretty excited to see if I could use it to simulate a little campfire in the comfort of my room. Original idea was to have a "dark souls" campfire dock but in the end I went with something simpler first as a proof-of-concept. Took 3 revisions to find the perfect tightness for that edc-18 shaped cutout.
Have many more mods planned ahead for this flashlight but parts are still on the way.
Planned future mods:
- Actual turboglow gaskets. Ordered 9 different colors to try. I think the price I paid was pretty cheap.
- Swap in Aluminum tube from a regular EDC18 to take weight down from 240g to 170g.
- Aluminum EDC18 upgrade to 10507 + AR coated glass lens
- Shorty Aluminum EDC18
- Use LOCA to fill in the air gap between optics and lens - see if that reduces reflection losses even further
- Mod to SST-20, try out some different color temperatures. 5000k, 4000k, 3000k pre-soldered MCPCBs already on the way.
- Maybe slice SST-20 dome for even better throw
- Anduril 2.0 update
Questions for the community
- Are there any resources to better understand how to flash Anduril 2.0 onto the EDC18? I would like to mess with the firmware and learn to customize it as well later down the line.
- Are there ways to unleash more raw power from the cells? Using 22a discharge cells vs 10a discharge cells on the EDC18 I find it difficult to spot any difference in brightness, whereas for my older Sofirn SP32 V2.0 the 22a cells seem to increase the brightness a good 50%
- If the rubber bunny switch cover gets punctured or falls off does the waterproofing fail? I have read stories of early models where the rubber would pull off in people's pockets but then could simply be squeezed back on.. Can't imagine how something like that would have any level of water resistance.
- I have tried putting my cheaper 4 year old side-switch sofirns in a waterproof testing chamber and they held up even at 50m depth, but I don't have the heart to stick my 5 day old EDC18 in a pressurized wet testing chamber. Anybody have done similar tests or real-world abuse with the EDC18 and can advise what level of water resistance I should be expecting?
