This is the Lumintop FWAA, a 14500 flashlight with Anduril 2 UI, 3x 519A 4000K LEDs, 1600 Lumens, an awesome tail button and more!
• My opinion
The FWAA surprised me at how powerful and useful it can be, the 3x 519A High CRI LEDs really pack a punch on this little guy; the tail e-switch is amazing, it sort of gives a feel of a mechanical while being electronic, it’s addicting to press it! The tiny size of this flashlight makes it really easy to carry, but a little small to hold.
Now the downsides, the driver is a FET +1, meaning it’s unregulated only having L4 and L7 modes without PWM and a higher efficiency, the FWAA could really use a constant current driver as an upgrade. Another thing is it doesn’t being compatible with AA batteries, using AAs on it would be really useful, especially on emergency situations. The flashlight gets hot pretty fast on the ceiling level or L6/L7, as the main body is so tiny and there’s little aluminum mass for heat to spread.
A feature that would really improve this flashlight is the addition of AUX lights, as it already has Anduril, AUX would improve even more the versatility of this flashlight.
| PROS | CONS |
| One of the most satisfying buttons I’ve ever used | FET unregulated driver with PWM on almost all modes (Except L4 and Turbo, which have no PWM) |
| Super compact | Turbo steps down pretty fast (Expected on a small flashlight like this) |
| IPX8 waterproof | No compatibility with AAs |
| Very powerful for it’s size with 3x High CRI Nichia 519A emitters |
• Price
Coupon Lumintop website (10% Discount!): LMPBR
The Lumintop FWAA in Gray is currently priced at $39.95 on Lumintop Official Store.
This link is an affiliate link, you can use it to buy flashlights you like and support me. Thanks.
• Box contents
- FWAA
- Lumintop 14500 1000mAh Li-ion battery
- Lanyard
- 2x extra O-rings
- User manual and Quality control card
• Body and build quality
Anodizing Colors/Material Options: The FWAA is available in Aluminum with 3 anodizing colors: Gray (featured on this review), Polished aluminum and Green. It’s also available in Titanium: Polished and Stonewashed, and in Copper.
Main body/Grip: The main body is very compact, even for a 14500 light. It’s very smooth, with knurling only near the head and on the tail cap. This ends up on the flashlight not being much grippy, especially as it’s so small.
Material: The main body is fully made of Aluminum, in a indisclosured alloy. The clip and tail button are made of stainless steel.
Threads: Only the head part is unscrewable, the bezel and tail cap are glued. The threads are trapezoidaç and not anodized.
Clip: The clip comes pre-installed and is not removable without breaking the glue on the tail cap. Totally made of polished stainless steel.
Tail stand and rolling: Without the clip the flashlight does roll and will fall off desks or tables.
Magnet: This flashlight doesn’t feature a magnet.
AUX lights: Unfortunately, this flashlight doesn’t feature AUX lights in any form. This is a big missed oportunity in my opinion, as it would improve A LOT this flashlight, as it lacks a color battery indicator and locator at dark environments.
Buttons: It features an e-switch on the tail cap, and oh my God. This is one of the best switches I’ve ever used. It’s so addictive to click it. The click is just perfect, not loud but still makes a sound; it works similary to a mechanical button, but it’s an e-switch! One of the best I’ve ever used so far.
Battery contact: Contact is made with the battery by a silver-plated spring on the driver, and a gold-plated spring on the tail cap.
Bezel: A standard EDC-type bezel is featured on this light, no fancy stuff. Just a normal smooth aluminum bezel. Stainless steel bezel would be an improvement.
Water Resistance: It has the IPX8 rating, so it’s rated for at least 1m underwater for 30min. It seems pretty well sealed, as most water entrance points are glued, like the tail cap and bezel, and the ones that aren’t have clear O-rings for water protection.
Size comparison: On the left the FireFlies Z1 Artemis (18650), on the center the Lumintop FWAA (14500) and on the right the **Convoy T3 TiCu (14500).
• Weight and size
Weight:
- With battery (Lumintop 14500): 52.9g
- Without battery: 33.6g
- Battery (Lumintop 14500): 19.4g
Size: 75.4mm x 20.5mm x 20.4mm - (height x head diamter x tail diameter)
• Battery, runtime, and charging
Battery: This flashlight is powered by a single 14500 Li-ion battery. A Lumintop 14500 with 1000mAh is included in the package. Batteries with USB-C also fit inside the flashlight for easily recharging it. To reach the 1600 Lumens a higher drain cell is needed as the included one seems to have around 4A CDR.
Battery Indicator: The FWAA has the Anduril 2 UI battery check feature, on which, after clicking on the main button 3 times while OFF, the flashlight will blink an amount of times corresponding to the battery voltage.
Charging: The flashlight doesn’t feature USB-C charging on body. Cells with USB-C can be used to make charging easier.
• Modes, Runtimes, Throw, Candela
Modes: This flashlight comes with 7 brightness levels by default on Ramp mode, going from 0.5 (Moonlight) Lumens to 1600 Lumens (Turbo). The levels are pretty well spaced if on the Stepped mode - which I prefer using to have more control of the runtime. Advertised specs:
| Level | Brightness | Throw |
| L1 - Moonlight | 0.5 | - |
| L2 | - | - |
| L3 | - | - |
| L4 | - | - |
| L5 | - | - |
| L6 | - | - |
| L7 - Turbo | 1600 | 100m |
Turbo: L7 (Turbo) level is pretty powerful, having 1600 Lumens advertised, pretty powerful for a 14500 small flashlight like the FWAA. The flashlight gets hot pretty fast on Turbo, as the main body is so small and there’s little mass for heat to dissipate.
Moonlight: L1 (Moonlight) mode is pretty good, with around 0.5 Lumens on Advanced mode, I tried configurating it lower but this already seems to be the lowest you can get. For some reason, on Simple mode the “Moonlight” is way brighter, not being a good moonlight, so I highly suggest using Advanced mode.
Blinkies: One of the coolest things about Anduril is it´s blinkies modes, I really love the “Candle mode” and the “Lightning” one. You have some fun blinking modes, and others like tactical strobe to choose from.
Lockout: It features electronic lockout on the Anduril 2 UI, by clicking the button 4 times the flashlight will lock and only moonlight will be available for use; It has mechanical lockout by unscrewing the head around 1/8th of a turn, the light won’t turn ON, but if it’s already ON it won’t turn OFF until the light is almost fully unscrewed.
Throw: The beam is Super floody, so it doesn’t throw far, being advertised to hit a max of 100m.
• Emitter, reflector and CRI
Emitter: The FWAA uses 3x of the famous Nichia 519A LEDs in 4000K, with a very pleasant neutral tint, high 9080 CRI. Excellent LED and one of my all time favorites.
Lens: A glass lens is placed in front of the TIR to protect it from scratches.
Reflector/TIR: A 3 LED TIR lens is present on this flashlight, it produces a pretty floody beam.
Beam profile: As mentioned above, the beam is Very floody, a hotspot is present but it’s so floody you almost can’t notice it. Very even and soft lighting. No artifacts, rings or anything.
PWM: The FWAA has PWM on all modes except L4 and L7 (Turbo) - which the AMC 7135 can handle on constant current, totally eliminating PWM on this level - on other modes, it’s fast PWM, usually above 10kHz, but still has PWM as it uses a FET driver. I didn’t see any PWM with naked eye, but if you are sensitive to it you may feel uncomfortable.
CRI: As usual, the 519A got excellent results on the test with an Opple LM4, with around 95 CRI, 86 R9, 0.0002 Duv on the L4 level. Surprisingly, I got even better CRI at L7 (Turbo), with 96 CRI and 95 R9.
Level L3 photometry test:
Level L7 (Turbo) Photometry test:
• Driver and UI
Driver: Unfortunately, the FWAA features a FET +1 driver, not regulated, not constant current, not very efficient. The driver is not the best feature on this flashlight.
UI: The FWAA uses the famous enthusiast focused Anduril 2.0 UI, it’s a very customizable UI, with a lot of options and settings to have fun with. I usually like to talk more about the UI, but as Anduril has so many features, I will not elaborate much on it as it would extend much the review.
Low Voltage Protection/Warning: The flashlight will power OFF when the battery voltage is below 2.8v.
Reverse Polarity Protection: The flashlight doesn’t seem to feature reverse polarity protection, so inserting the battery with the wrong polarity side will short the device, damaging the LED, driver.
Temperature Control: It features a temperature regulation based on the internal temperature, so when the temperature gets too high the flashlight will dim down to avoid driver and LED damage.
Thank you for reading my review
A special thanks to Lumintop for sending this flashlight for me to review!
I am not being paid to do this review, everything here is my honest opinion.
Some links are affiliate links, this doesn’t impact on my opinion for the reviews. You can support me by using the links to buy flashlights you like.
