Help required finding ramping driver for sd75. I would like to replace the stock driver in my sd75 with a ramping driver similar in operation to the BLF Q8. Does anyone know where I could purchase a such a driver. I would like to keep the same battery carrier keeping the functionality of the tailcap charging circuit. Needs to be posted to UK. Many thanks Britlightbruce.
The SD75 is a 32mm driver IIRC… look up member Lexel… I think he makes 32mm drivers now… he didn’t back when I did my 2 SD75’s…
I used his 30mm Narsil 2S/2P driver but it takes a little modding…clearing out the ID of the driver retainer ring to clear the 7135’s and making adapters out of copper, which also helps keep the driver heat sinked, the 7135’s run cooler…
