It depends on a couple of things. How high is the battery internal resistance and what is the current path on the light like.
Assuming a direct connection from battery to the emitter (no host, wire or contact resistance) with a 0.050ohm battery such as the Sanyo NCR18650GA the voltage sag and emitter forward voltage cross at about 6.6 amps which is high but doesn’t necessarily break the emitter yet. Add other resistances and you’re fine. 25R is a lower IR cell and could provide too much current.
