To start off, I now know what you small die, thrower enthusiasts are excited about. I find it amusing I’ve discovered this in a 3*AAA light with an old Cree LED… an impulse purchase from Lowe’s ($11.99). Unfortunately, I discovered a hollow pill upon dis-assembly but that is really the main draw-back about the light and I demonstrate a way to cure that.
The pros:
smooth bezel and tail cap;
combination smooth and orange peel (plastic) reflector;
reflector is the same size that comes in this popular light;
reflector will fit an XM-L, if you dare;
rubber grip;
believably water tight with o-rings in the right spots;
tight spot, of course, but nice spill as well;
Not a warm tint but not cool either;
1.3 mA on high with a laptop battery pack pull (Sanyo 18500);
Even with alkaline batteries, the output is better than 130 lumens (spec on package).
This post is mostly about an excuse to use some new tools and an idea (likely an inspiration from reading Old-Lumens’ posts) to use a copper end cap as a heat conductor.
So, here’s to new tools (not shown is my new cordless drill):
And tinkering with the idea:
Ultimately, the tinkering led me to discover I needed to make a flip of the new part:
Because the battery tube couldn’t be threaded to the head with the new pill enhancement:
And a comparison of size to other popular models:
There are better lights for the price but 3*AAA format lights are comfortable and cheap enough for handing over to the brood for a little dark time exploration.
