M4D_M4X
(M4D M4X)
1
Hello my dear friends!
i got the groupbuy for 2 new Lumintop flashlights:
(the links in the pictures and text below take you to the shop for additional info)
Features:
Utilizes XP-L HD LED with a lifespan of 50,000 hours
Powered by one AA or one 14500 rechargeable Li-ion battery, 550 lumens max output
Only 90.6mm in length, 26g in weight, handy and compact, easy to carry
Two ways to select outputs: Tail switching or twist the head
Made of aircraft-grade aluminum alloy with anti-scratching type HAIII military grade hard-anodized finish
Double-side AR coated, tempered window resists impact and thermal shock, max 99% light transmission
Waterproof to IPX-8 standard
Package included:
1 x LUMINTOP Tool AA 550LM Portable LED Flashlight (Without Magnetic Tail)
1 x O-rings
1 x Lanyard
1 x English Manual
Features
Utilizes OSRAM LED with 50,000 hours lifetime
2 modes with a max 130 lumens output and an up to 7.5 hours runtime
Micro USB rechargeable with built-in charging indicator
built-in 3.7V/80mAh 10180 Li-ion battery, fully charge within 57 minutes
Tiny and light-weight design, 41.5mm in length and 11.8g in weight
Three colors optional, black, silver and pink
TIR optical lens creates a soft and balance beam
Glow-in-the-dark O-ring easily locates the light in the dark
Simplify twisty switch, easy operation within one hand control
Make of aircraft-grade aluminum alloy with military grade type III HA matt finish
IP68 rated dust and waterproof protection, impact resistance to 1.5 meters
Size: 41.5*14mm, Net weight: 11.8g
2 years free repair, limited lifetime warranty
Package Included:
1 x EDC Pico Keychain Light
1 x 10180 rechargeable li-ion battery (bult-in can not remove)
1 x Charging cable
2 x O-ring
1 x Keychain
1 x User manual
check the member deal list or use the form below to get the deal!
lotrbfme
(lotrbfme)
2
Interested! I love the tool AA. And these colors are really nice!
contactcr
(contactcr)
3
I guess it’s the clip color but that Tool AA looks white in the picture.
M4D_M4X
(M4D M4X)
4
LT confirmed its a Tool AA 2.0 in "Panda White"
X31
(-X3-)
5
They made a 2.0 version with better mode spacing, good. But they kept the useless flimsy clip… too bad, the Tool AA is nearly the perfect EDC (in AA/clicky category of course)
the pico looks interesting, but we need more info about the led
(micro usb, honestly, the should stop using them in 2019)
Muto
(Muto)
8
Pico uses non removable 10180, they are all junk, will not buy any light with that battery ever again.
Deal killer no matter how cute.
White Tool AA on the other hand is neat and will buy one.
Thanks!
Keith
Kindle
(Kindle)
9
I never got around to picking up the AA Tool. Was thinking about grabbing one the other day…so this is clearly a sign.
lotrbfme
(lotrbfme)
10
Thanks order placed for 2 x pico!
M4D_M4X
(M4D M4X)
11
thank you guys! :beer:
i use the 10180 in my blackwater kite Ti for 2 or 3 years now on my keyring
my wife has the SS on her carkey
no issues so far (no electronics, no parasitic drain)
d_t_a
(d_t_a)
12
I have some questions about the new colors of the Tool AA 2.0 - grey and white.
1) are these gray / white Tool AA similar to the Tool AA v1 or the Tool AA v2.0
- the above specs list “550 lumens” max rating, which is the rating for the Tool AA v1
(the Tool AA v2.0 would list “650 lumens” max rating)
2) do these gray/white Tool AA 2.0 include the magnetic tailcap option as a regular accessory in the box package?
I’ve noticed that some Tool AA 2.0 from different shops include the magnetic tailcap while some are an optional add-on, so would like to clarify this.
The item description just mentions “optional magnetic tailcap”, but the package contents doesnt’ specifically list it.
Thank you.
M4D_M4X
(M4D M4X)
13
i think the magnetic cap is not included (i will see when my order arrives)
i was told its a Tool 2.0 technically (chinese copy paste is...*+***)
SKY69
(SKY69)
14
Banggood took 10 days to figure out that they are out of stock of the white tool and cancelled the order. Disappointing to say the least.
M4D_M4X
(M4D M4X)
15
please PM me the ordernumber
Eventually interested in the Tool AA grey! E-mail submitted
Thanks Martin!
SKY69
(SKY69)
17
I just received a new message that my order has been shipped. All is well once again. Thanks Martin as always.
M4D_M4X
(M4D M4X)
18
got both colors - funny how the color change with different lightsource
mortuus
(mortuus)
19
can u ask lumintop to make these in copper?
