Hello my dear friends!
due to the good response banggood has been able to get a better deal for the next batch!
just use the form below to get the updated price ;)
Nitecore Tini SS
XP-G2 S3 380LM USB Rechargeable Mini Keychain Light EDC LED Flashlight
Description:
Mini Keychain Light for Everyday Carry
Meet the smallest and brightest keychain flashlight, the NITECORE TINI. Continuing to push boundaries, this super mini keychain light utilizes a XP-G2 S3 LED for an impressive 380 lumens max output with 70 yards throw. The TINI operates similar to the best-selling TIP via an intuitive dual-button control. Access four brightness levels and switch between two operating modes for custom output no matter what the usage. Daily mode provides constant illumination while demo mode will automatically turn off the light after 30 seconds of inactivity to help preserve battery life.Weighing 0.47 ounces and measuring 1.7"x1"x0.45", the TINI is the go-to choice for everyday carry, emergency backup and household tasks.
Built-in Battery with up to 60 Hours Runtime
A built-in 280mAh Li-ion battery provides a max runtime up to 60 hours and is rechargeable via the built-in Micro-USB port. To charge, plug-in any micro-USB charging cable into the micro-USB port and connect the USB end to any available USB power source. An integrated power indicator located beneath the switches reports remain power levels so you'll know when power is low.
3 Beautiful Stainless Steel Finishes
Now available in 3 stunningly gorgeous stainless steel body finishes, there's a NITECORE TINI for everyone. Whether you pick Glacier, Jet Black or Tropical, the stainless steel edition of the TINI features the same ultra bright output in a body that's just slightly heftier for a better overall feel in larger hands.
Features:
- 3 stainless steel body finishes available
- Utilizes bead surface optic lens for uniform soft light
- 4 brightness levels with instant access to turbo
- Dual switches for easy operation
- Intelligent memory function
- Integrated power indicator
1 x NITECORE TINI Stainless Steel LED Mini Flashlight
1 x Key Clasp
1 x Warranty card
1 x User manual
more Info:
