This is my dream light. Can’t decide now between the TK75 or an L6 or the upcoming Q8
Hmm, an L6 + Q9 costs the same as the TK75……
That said this is the best deal you will find on a TK75.
and both probably fill the same niche as flooders. I am guessing the TK75 is a mix between a thrower and a flooder
A few things, Cometas still available at $40?
Also, are the protected 26650 5200mAh Keeppower cells (newer?) measuring less than 70mm available with a discount code?
And can I get the Xtar SV2 code? Thanks!
Thanks Start90a and Martin, I just ordered one unit.
the Code “TypeCBW-C8” not working for BlitzWolf USB Type C BW-C8 Car Charger?? :frowning:
Martin do you happen to have any discount code for the Acebeam EC60? HKE has it for $120 but that’s way out of my budget. thanks
Thanks. TK75 ordered.
acebeam is hard on MAP - sorry :(
but i might have a way in the near(er) future... ;)
Good Luck with Acebeam, Martin!
Every dent in MAP is a consumer victory in the battle!
CHUWI 10050mAh 18W Two-way Quick Charge QC3.0 Power Bank
only US$ 20,99 now in presale! (then 22.99)
Looks like the code was limited to 500 units.
Thanks! Ordered one TK75
Thanks for the codes. I was able to get a light I wanted for only $8.
Keep up the good work!!
Not familiar with Chuwi. Do they have a good reputation?
did you get the Fenix TK75 for only $99.99?
then you might need one (or more ;) )
Extended Runtime Kits
For Fenix TK75 TK76 TK61 Flashlight
with code bgf157 only US$ 22.79
seems to be a new brand - i found no real test
i ordered one because the QC 3.0 feature...
Got the TK75, good price, thanks Martin.
Was there a skilhunt h03 code?
Edit. Found it.
Damn! I wish I needed a TK75, but I have a 2013 version. I’m not sure if it’s worth upgrading. Amazing price though!
