1. 18GT-36 3600mAh Li-Ion 18650 battery included, max runtime up to 170 hours.
2. One-Touch Turbo with either side and tail switch, One-Touch Low with tail switch, easy to operate.
3. Independent tail and side switch, each with full set of features and easily adapted to any scenarios.
4. For side switch, the current output mode will be memorized when the flashlight is turned off, the output will automatically return to this mode when powered ON.
5. Unique lockout mode of both side and tail switch prevents accidental operations; avoids battery drains during storage or travel and preventing unintended direct shining into eyes.
6. Intelligent Battery Load Check System compatible with a wide variety of batteries.
7. Integrated Micro-USB charging port supports 1A fast charging.
8. Newest ITS Intelligent Temperature Protection System, monitors internal temperature and adjust output for maximum brightness, protects LED and internal components to ensure safety, stability, optimum performance, and user comfort.
9. Aerospace Aluminum Alloy construction; CNC precision machining; HAIII Mil-Spec anodizing, lightweight and abrasion resistant.
10. Reverse-polarity protection prevents damage due to incorrect battery orientation.
11. Compact Size, comfortable any grip.
12. Hardened glass lens with AR coating; scratch resistant.
13. Updated reflector design, coated to provide the perfect beam profile for exceptional illumination at any distance.
