i can usually pretty much pick them out in change just by the patina…
i just started saving them years ago.
the ZINC melts easy and you can cast them easily at a low enough temperature, plus the zinc goes up and down in cost, you never know… just made a few ingots, not like i CAST anything useful (would like to though)
and the copper is a semi precious “boullion” now, lol… plus? i use a couple pennies now and then for contacts electrically, this is the first 2 times i have exploited their heat sinking, and this is the first time i think i ever exploited a copper pennies malleability.
i have been consistently “playing” with craptastic budget lights from TRACTOR SUPPLY.
theres been three….
one is the tiny 3-AAA zoomie, a unprotected 18650 JUST fits in, and gives around 800ma on high (low and blinky too). fairly short focal length plastic aspherical. i have gotten a little fond of it, and am gonna play with a few more, they are only 9.99
two is the bigger brother to that one, its a small 2-C body, same design as the little zoomie. longer focal length on the aspherical makes it more desireable, as does the slightly wider diameter of the lens. I run it on two 18500 LiFePO4 i picked up for solar lights at the home improvement store.
its almost the perfect size… small 2C body, side clicky is great, as the world has too many BIG “tactical” lights with the awkward tailcap switch… and the crap driver gives up almost 2A with teh 2 lifepo4.
the last tractor supply light? they have a clearance on a 3-D zoomie. wider diameter plastic aspherical yet, and longer focal length too. At 9.99 clearance? I have 3 already, and plan to pick a few more up for later.
none of the 3 seem t be GREAT at heat sinking? but, they arent too bad… i plan on not going over 3A on high when i finally buy real drivers. The 3D zoomies? driven at reasonable levels (no overclocking, lol) thre D cells should give a really good run time,plus, i cant trust giving a li-ion light to a non-flashaholic.
the little 3-aaa that just takes an unprotected 18650? its okay, and i realize i could prolly get better for teh same money on line, but something about buying “in your hand” at the store… the 2C body? i actually really like… you just dont SEE 2-C bodies a lot in zoomie… small size, good handfeel, side clicky… and when i get a real driver, it should be a great light.
the 3Ds on clearance? you just dont SEE budget 3D zoomies… not for 10 bux anyways, even online. i’ll prolly pick one up a week, till they are all gone… and put them in a box, for later…
they might not be the BEST CHOICE to try to make a 99 amp monster out of? but for “sane” power levels, they seem lik they will be okay.
plus? i think i am the only BLF guy exploiting tractor supply budget lights, lol… i plan on doing 3 reviews after i get drivers and preferred emitters in all of them.
i wont have the best “wow” lights? but… i will be the only one with somethign different.
if theres cheap budget 2C and 3D zoomie hosts out there on line? at 10 dollars? i havent seen then… the 2C in particular is the perfect hand size.
tail cllickys are great, but, only in a small handsized light…. once a light goes over a certain short size? the side clicky is more comfrtable and makes a LOT more sense… nothing i hate more than a 3D light, thats therwie great, but with a “tactical” tail clicky…
